EQS EQS (V297) sedan
Hyperscreen on 450+
Old Sep 12, 2021 | 05:52 PM
AstroCV's Avatar
EQS ordered, 2018 GLS
Hyperscreen on 450+
Anyone able to secure a hyperscreen on a 450+ build? I was told they were unavailable with chip shortage and their may be some 580s with it left out. Would the base dash run the same operating system and interface?
Old Sep 12, 2021 | 06:26 PM
W205C43PFL's Avatar
Yes, it is the same screen you get in the W223 S-Class. Which means you no longer have the front passenger screen showing the Vison AVTR and the screen isn't under the same piece of glass that the hyperscreen is.
Old Sep 12, 2021 | 07:07 PM
JoeMa's Avatar
26 EQS 400 SUV, 23 EQS 580 SUV (sold), 19 X7 (sold), 17/14 GLS550 (sold), 13 GL550 (sold)
There would be some minor differences since the base screen is not as large as the center area of the Hyperscreen but I would expect they function nearly identical. I've seen this set up in the new S Class and it looks great. There should be a significant savings going with the base screen over the Hyperscreen.
Old Sep 12, 2021 | 07:10 PM
W205C43PFL's Avatar
Here is how the EQS without the hyperscreen look like, courtesy of forum member js_cls
https://cimg8.ibsrv.net/gimg/www.mbw...19e04c2174.jpg
Old Sep 12, 2021 | 07:16 PM
E55Greasemonkey's Avatar
This place is a joke.
Don't be fooled by the hyperscreen. It's nothing more than 3 rectangular displays under one piece of glass. You can see the 3 cutouts through the blacked out glass. Now if the entire thing was a touchscreen, then I'd be impressed.
Old Sep 12, 2021 | 07:18 PM
superswiss's Avatar
2019 C63CS
As far as I know it's the same OS. You just don't have the passenger display and it's not a single piece of glass. The UI is arranged slightly different mainly due to the standard display being portrait, while the Hyperscreen is landscape. At the link below you can see the two interiors side-by-side. I'm not surprised the that the Hyperscreens might be hard to come by, and I'm actually kinda split on it. Word is coming in from reviewers that the passenger display is rather distracting to the driver. While it tracks the driver's eyes and turns off if the driver looks towards it for a second or so, many are reporting that the constant light from it in the peripheral vision is quite annoying, combined with ambient light reflections on the glass.
https://www.motor1.com/news/497310/m...screen-photos/
Old Sep 23, 2021 | 03:48 PM
DBGator's Avatar
EQS Sedan, W222, W221, W220
If you have the full hyperscreen, can you turn off the passenger side if you find it distracting?
Old Sep 23, 2021 | 03:53 PM
W205C43PFL's Avatar
I thought when the driver looks over, it turns off?
Old Sep 23, 2021 | 04:01 PM
superswiss's Avatar
2019 C63CS
Not as far as I know. See below
Yes, it does, but apparently it takes a second or two. A quick glance doesn't turn it off. You have to be deliberately looking at it and then it turns off after a moment. I guess it's so that it doesn't constantly turn off if you just quickly look at the passenger side mirror for example and the passenger is actually using it. It would be pretty annoying for the passenger, if it immediately turns off if the driver just glances over to them.
Old Sep 23, 2021 | 04:16 PM
W205C43PFL's Avatar
I see, thanks for your explanation. I am also hoping that MB uses "privacy" glass for the passenger display so the driver can't see it from their view. However, since all screens are under the same glass it wouldn't be feasible.
I am also hoping that MB at least use the same sensors used to detect if there is a passenger for the airbags to be active to determine if the screen should be on at all.
Old Sep 23, 2021 | 05:50 PM
DBGator's Avatar
I was sort of wondering what happens if the passenger wants to take a nap at night, for instance. What if the passenger does not want it?
Old Sep 23, 2021 | 06:19 PM
wings1969's Avatar
2022 EQS 450
If you are not getting the hyperscreen and want the "look:" as posted above, order the backlit trim option. This is 51H /331 in the DOG. I was the first to order this combination and it created a problem in the MB system which took a week to correct. If you don't order the backlit option, your right side dash will look like the option for the center console; i.e. wood or whichever is on the center console trim.
Old Sep 24, 2021 | 11:46 AM
js_cls's Avatar
I also think this is the best option for the "standard" display/dash look. I think getting the wood trims is a bit too much for the dash, the backlit option with the three pointed stars just visually look better and less cluttered.
Old Sep 24, 2021 | 05:37 PM
MBNUT1's Avatar
2010 E350 4Matic
It's the driver's display (same as the W223) that I find objectionable on the base screen. This is what makes the hyper-screen so much more desirable in my opinion.
Old Sep 25, 2021 | 09:07 PM
JoeMa's Avatar
Everyone has different tastes but I looked at this design in the new S Class and must admit that it looks better in person than I thought it would. In fact, it looked quite nice. Maybe you've already checked out the new S Class, but if not, take a look in person.
Old Sep 26, 2021 | 09:29 AM
MBNUT1's Avatar
2010 E350 4Matic
Nowhere nearly as elegant of a look as the hyperscreen.
Old Sep 26, 2021 | 09:46 AM
places's Avatar
No more MB:(
I agree. I'm surprised they didn't implement the hyperscreen on the S, it's next level. The iPad thing is a mess.
Old Sep 26, 2021 | 10:33 AM
JoeMa's Avatar
The Hyperscreen is a $7,200 option over and above that so called "iPad mess". It may be worth it but I'm guessing most on this forum hasn't even seen the Hyperscreen in person yet. I've seen the S Class in person and it's not bad at all.
Old Sep 26, 2021 | 10:56 AM
AstroCV's Avatar
The hyperscreen has limited availability and only available on the 580. Upgrade to hyperscreen on the 450+ is not an option right now per my local dealer. If available I might have upgraded, but i would rather get a 450 this fall than wait 6-12 months for the upgrade to possibly be available with all the shortages.
Old Sep 26, 2021 | 11:15 AM
places's Avatar
No more MB:(
There was a time that the S class got the best and newest, no compromises but not anymore. As for the iPad, certainly is subjective. "Not bad" is not acceptable for an S, or maybe it is now.
Old Sep 26, 2021 | 03:16 PM
JoeMa's Avatar
Alright, the new S Class dash looks “very good” in person. I’ve watched numerous reviews of the new S and have not heard anyone mention the instrument display being a problem, just you.
Old Sep 26, 2021 | 10:55 PM
places's Avatar
No more MB:(
I guess I'm the only one in the world that has an issue with the Tesla screen. You should read some more threads here.
Old Sep 27, 2021 | 08:58 AM
JoeMa's Avatar
I'm sure you're not the only one who doesn't like the new S instrument display and I see you owned a number of S class Mercedes with more elegant instrument displays, but new display looks pretty good in person (IMO). As for a Hyperscreen option in the S Class, due to shortages, MB probably had little choice but to reserve the Hyperscreen for the launch of the EQ models (EQS, EQE, EQS SUV, etc.) until production of the Hyperscreen can catch up to demand. That said, anyone who ordered an EQS 450+ and are not getting the Hyperscreen, wait to see it in person. You may be very happy with it and will save $7,200.
