EQS EQS (V297) sedan
Porsche fan on range
Old Dec 13, 2021 | 06:00 AM
Newbyloub's Avatar
2018 S560; 2022 EQS450+
RANGE - had posted in wrong forum. Sorry.
Porsche fan’s point of view on tange…
Subscribed
Newbyloub , Yesterday 08:26 PM
The EQS will not have "better range" than the
Taycan, it will have a "bigger battery" which will
absolutely make it drive like a boat. Efficiency
will likely be almost the exact same. Range
claims mean nothing, every company except
Porsche drastically overstates the range of their
EVs.. Porsche is literally the only company that
undersells it.
The interior is a matter of perspective. The EQS
looks way over the top and I much prefe the
clean, minimalistic approach of the Taycan”
My thinking - “Range,” given that driving conditions and situations, and driving styles, vary so much, doesn’t mean a thing.
All that matters is, “Can I get there as I am,
and if not, where can I get what I need?
To each his own.
Edit Quote
Old Dec 13, 2021 | 07:10 AM
Mikey53's Avatar
Veteran: Air Force
2016 C300 4Matic traded in for a 2022 E450 Coupe
“Mercedes-Benz EQS Exceeds EPA Rating In Edmunds Range Test”
To each his own.
Old Dec 13, 2021 | 07:20 AM
Diesel Benz's Avatar
I don't understand this view (not the only thing I don't understand unfortunately ). If all that matters is, “Can I get there as I am, and if not, where can I get what I need", isn't it more likely to happen if the WLTP (or any other) range is better than for another car? The figure may not reflect one's personal driving style or current weather etc. but still the car with the higher rating is likely to get further. Exceptions may be e.g. from the lack of a heat pump for interior heating at cold weather but I think all EVs now have a heat pump (all Mercedes since the first B-class EV).
Old Dec 13, 2021 | 07:51 AM
Newbyloub's Avatar
Okay -
I don’t understand “WLTP.”
Of course , everyone looks at “range” as he chooses to, I look at it as I expressed it - can I get where I want to go? If not, plug it in.
I don’t get the “heat pump” connection.
Old Dec 13, 2021 | 08:08 AM
Originally Posted by Newbyloub
Okay -
I see, makes sense, but EQS should have the fastest charging capability amongst EVs (I've not seen any comparison to Porsche, just seen news titles). EQS should then better suite for trips where top up is needed during the trip.
Old Dec 13, 2021 | 09:01 AM
Newbyloub's Avatar
I see, makesense, but EQS should have the fastest charging capability amongst EVs (I've not seen any comparison to Porsche, just erseen news titles). EQS should then better suite for trips where top up is needed during the trip.
No battery scientist - I thought there is a limit to how quickly a battery can accept charging. Overnight suits me just fine.
From everything I’ve read, my 450+ will take me farther/longer than I want to drive in one day, just like my ‘18 S560 will. I don’t need anything more.
stealth.pilot's Avatar
2022 Mercedes EQS 580
EQS has a usable battery capacity of 107.8 kwh. Taycan has a usable battery capacity of 83.7 kwh.
The Edmunds range test (which I consider the most objective because it is performed on real roads at identical speeds) showed the Taycan achieved a real-world range of 263 miles, and the EQS achieved a real world range of 422 miles.
This means the EQS did 3.9 miles/kwh, and the Taycan did 3.14 miles per kwh. The EQS is also larger and heavier.
So the EQS s substantially more efficient than the Taycan. Does it drive in a more boat like manner than a Taycan - yes because it is heavier. But nonetheless it is better EV engineering from an efficiency standpoint to make a car that much larger with higher efficiency.
Old Dec 13, 2021 | 11:56 PM
MBNUT1's Avatar
2010 E350 4Matic
The Edmund's comparison below has the EQS at 3.4 miles per kwh vs the Taycan's 3.1 (range is 323 miles)
https://www.edmunds.com/car-news/ele...s-edmunds.html
The Taycan 4S in the comparison is AWD vs the EQS 450+ RWD, additionally the Taycan 4S's 0-60 is 3.8 vs Mercedes reports the EQS 450 0-60 to be 5.9 seconds.
Old Dec 14, 2021 | 11:29 AM
js_cls's Avatar
Just as a clarification for everyone, the original post is a copy of a post made on a Taycan forum back in March before the car was unveiled.
Taycan Forum: EQS vs Taycan
Old Dec 14, 2021 | 02:49 PM
c4004matic's Avatar
17 E43; 21 GLS580
Why would we even compare the 2? Have you ever seen a car article comparing a 911 to an S class? Its an oxymoron.
Old Dec 14, 2021 | 05:09 PM
MBNUT1's Avatar
2010 E350 4Matic
The Taycan is closer to the Panamera which does get compared to the S Class. Having said that, the EQS is a luxo-barge vs the Taycan which is a proper sporting vehicle.
Old Dec 15, 2021 | 08:19 PM
From a size perspective a Taycan is in between a Mercedes C-Class and an E-Class. The Panamera is a little bigger than E-Class. From a cabin perspective the Panamera has a much larger cabin than the Taycan. They are different classes of vehicle from a size perspective. Comparing a Taycan to an EQS is ludicrous except when it comes to price.
Old Dec 15, 2021 | 08:24 PM
Newbyloub's Avatar
Some of the questions asked here and opinions voiced just don’t make any sense at all.
Old Dec 15, 2021 | 10:31 PM
MBNUT1's Avatar
2010 E350 4Matic
Old Dec 15, 2021 | 10:34 PM
MBNUT1's Avatar
2010 E350 4Matic
Note that the post was in response saying the Taycan comparison was like comparing the EQS to a 911 which I would submit is further from a Taycan than an EQS, beginning with they are both 4 door BEV's. As much as I like the notion of owning a 911 I wouldn't have one because of the NVH created by the chassis and the ICE. Not so for the Taycan. Completely different cars.
This reviewer thinks that the Taycan and the EQS are in the same category.
https://www.taycanforum.com/forum/th...-reviews.7050/
Old Dec 15, 2021 | 10:40 PM
MBNUT1's Avatar
2010 E350 4Matic
