One week experience with EQS 450+
- The extended mobility tires are Pirelli P-Zero Elect A/S 265/40R21. 500 A A rating. I believe this is a brand new line of tires from Pirelli. They’re very grippy, even at near-freezing temperatures. But they do seem to ride a bit firmer at the recommended 41 PSI than similarly sized Michelin PS4 summer and Latitude A/S tires I’ve had on other cars.
- The ride height is not user-adjustable. This was a surprise as the website and even owner’s manual prominently mentioned this feature. I confirmed with my local dealer and the selling dealer that this is true for all US-spec (non-review) cars. They said there needs to be a code for the “suspension plus” feature which US cars don’t have. I wasn’t able to get confirmation on whether the ride height lowers at high speeds or if the suspension is self-leveling. The damping does seem to be adjustable as advertised.
- There is an enormous cavity under the hood in the 450+. It is beneath the massive HEPA filter and connecting air ducts but could easily be converted to a frunk for at least carry-on sized luggage if the packaging of the filter had been slightly different. But it seems reasonable that the empty space will at least partially be occupied in the dual-motor EQS models which is why there's no frunk.
- Related, the hood opens normally with a lever underneath the driver-side dash. The HEPA filters (there are two sequential filters) is front and center under there and can be changed with just 3 clips, so much easier than a regular cabin air filter that often lives in hard-to-reach corners.
- The acceleration from a standstill and above around 75MPH is amazing. The motor seems to have lots of torque off the line and sustained torque higher in the rev-range. Compared with my other car, a Tesla Model Y with a faster 0-60 time, the EQS feels faster at low and high speeds. The Tesla is faster in the midrange, roughly 30-60 MPH.
- The brakes are genius. The Vehicle Info screen shows that the first 40% of pedal travel applies 10% of brake pressure, with the remaining 90% brake applied by the last 60% of pedal in a very predictable manner. It’s very easy to drive smoothly by using the first 40% of brakes and easy to drive in a sporty manner by mostly braking with the remaining 60%.
- The ride in “Comfort” mode feels much firmer than the W223 S-class that I test drove earlier. There is no mistaking an EQS for an S-class if someone were to ride in them blind-folded and with earplugs. The may be partially caused by the 21in wheels on the EQS.
- All parts of the car I could reach, including all exterior body panels, don’t stick to magnets. So they’re likely all Aluminum, or other lighter metal/alloys/carbon material.
- The rapid heating seats take about a minute to warm up from near-freezing temperature.
- There is a traditional H6-sized 12V lead-acid battery under the hood.
Your report is encouraging.
Does the car elicit much reaction from others? Do people realize that it is electric?
About 9 minutes into this video, the salesman opens the front hood -
A couple of items were unincluded. The $200 integrated toll pass is there but was not charged. The emergency charging cable was missing and the $250 for it was credited back.
VIN ends with NA0047XX
Production date is Oct. 2021
Arrived at the port in Baltimore, MD around Dec. 7th 2021. I picked it up from the dealer the following week.
For the regen braking, I’ve been using mostly normal and intelligent recuperation. Strong regen felt similar to Tesla and is sufficient for one-pedal driving. Intelligent mode is quite magical and feels like having adaptive cruise all the time but the follow distance is a bit tight for me in stop and go traffic and not configurable.
The car was able to seamlessly connect to the chargers and the sessions available for free. The initial set up of Mercedes Me Charge on my iOS Mercedes Me app was pretty seamless too.
The car was at 30% charge and both stalls were unoccupied. I did not precondition the battery but it seems like at least 50KW should still be possible. Temperature was about 35F.
In terms of reactions, I got a hearty thumbs up from an E-tron GT driver once; that's pretty much it. The EQS seems to fly under the radar more than the Tesla Y that gained a lot of attention when I got it around this time last year.
Thanks for this!
We don’t get a lot of snow, and I wanted my EQS.
The Cincinnati dealer is writing orders for 450s.
I didn’t want to wait for a 580.
You cannot be expected to understand everyone’s thinking.
As with other airmatic mercs there is a +1 setting for deep snow or rough roads, however, there is no button. The setting is in the car settings menu. An Icon of a car with an arrow on top. It only works at slow speeds. Maybe that particular part of the system is not available here but I seriously doubt it, again its part and parcel of all airmatics.
M
