EQS EQS (V297) sedan
Trunk Liner
Old May 30, 2022 | 08:04 AM
Cincy2's Avatar
EQS 580
Trunk Liner
The WeatherTech trunk liner for EQS is available. Nice fit.
Cincy
Old May 30, 2022 | 09:50 AM
TH22's Avatar
2023 EQS 580
Looks like a good fit. I have a set of weathertech mats for my Yukon Denali XL. Life saver.
Old May 30, 2022 | 10:19 AM
c4004matic's Avatar
17 E43; 21 GLS580
Cincy
mine is waiting by my front door. Its Cocoa. Il post when I return
Old May 30, 2022 | 11:12 AM
asdf's Avatar
Got mine, too. Thanks for the heads-up.
Nice fit.
I also got off those storage bags that hang from the headrest so I can organize the loose odds and ends.
Old May 30, 2022 | 12:52 PM
c4004matic's Avatar
17 E43; 21 GLS580
My "Go kit" including the Ford mobile charger (level 2) a Tesla tap, tool kit, jumper cables, and tow strap, plus the tire fx kit all fit in the storage compartment along with a gun safe! Not so small after all!
I wish the compartment was lockable but since you never do use the key I understand. Another thing that would have been nice was a metal achoring spot to tie my safe's anchoring cable.
Old May 30, 2022 | 01:44 PM
asdf's Avatar
I plan to use the Tesla tap only when absolutely necessary since my dealership's foreman actually advised against it.
My tires are no flat, but will bring a Lucid tire kit. The only problem is I still have to figure out how to install a 12 V socket. Otherwise, I may just bring along one of those 12V lithium jumper.
What's the Ford mobile charger?
Old May 30, 2022 | 03:05 PM
wings1969's Avatar
2022 EQS 450
There is a 12 volt socket under the passenger side under the glove box, looking underneath to the left side but it has a spring loaded cover you need to flop open. Cleverly hidden and hard to find.
Old May 30, 2022 | 04:09 PM
asdf's Avatar
My car doesn't have it. Confirmed by the dealer. I'm kind of disappointed, needless to say.
Old May 30, 2022 | 04:11 PM
Newbyloub's Avatar
2018 S560; 2022 EQS450+
Thanks on EQS Weatherhead trunk liner.
Just ordered one in tan for my Cardinal Red 450+.
I have to say I don’t understand why MB would put a very light color in the boot or on the steering wheel. Simply doesn’t make sense
t me.
Old May 30, 2022 | 04:34 PM
Tjdehya's Avatar
2023 AMG EQS
Why does Cincy2's look so much better than ASDF? Are both of those the same product?
Maybe its the angle from where the pics are taken but I want to order the one that Cincy2 has lol
Old May 30, 2022 | 04:41 PM
c4004matic's Avatar
17 E43; 21 GLS580
Because...... you should never, never use flash on a cellphone!
Old May 30, 2022 | 05:43 PM
asdf's Avatar
Yep, just the angle of view. There's only 1 version listed by Weathertec.
Old May 30, 2022 | 09:50 PM
stealth.pilot's Avatar
2022 Mercedes EQS 580
Does Mercedes make a trunk liner?
Old May 30, 2022 | 09:53 PM
asdf's Avatar
Well, last time I checked, they didn't have any accessories for the EQS line yet.
Old May 31, 2022 | 03:01 AM
c4004matic's Avatar
17 E43; 21 GLS580
I wouldnt hold my breath....
Old May 31, 2022 | 03:05 AM
c4004matic's Avatar
17 E43; 21 GLS580
There has to be a way for the dealer to do so. Its not rocket science and quite frankly its a MB truck sourced part. Thats why its hidden away where no one can see it!
Old May 31, 2022 | 09:23 AM
DaleW's Avatar
EQS 450
How do you use the tire inflation kit? Where do you plug it in?
Wish they had included a 110v outlet so I could charge my laptop.
Old May 31, 2022 | 11:34 AM
Soulman's Avatar
Range Rover Land Rover
Cincy
Great, thanks for showing. I'm going to order one too.
Old May 31, 2022 | 11:48 AM
bgrewal's Avatar
EQS580
I will definitely order one once I get the delivery date confirmed.
Old May 31, 2022 | 12:21 PM
There are some but no trunk mat as far as I can tell.
https://www.kunzmann.de/shop/en/prod...benz/eqs/v297/
Old May 31, 2022 | 11:22 PM
asdf's Avatar
That's exactly the problem. No power source for anything.
The dealership's justification is the car does not have a 12 V socket because I have run-flat tire.
This logic is frankly illogical because who's to say what tires I'm going to change to in the future.
Old May 31, 2022 | 11:24 PM
asdf's Avatar
They're looking into how to install one and at what cost to me.
Old May 31, 2022 | 11:34 PM
Radman991's Avatar
2005 SL 500. 2015 S550. 2016 GLE400 2018 S560
Its hard to believe whether they install a 12 v socket is based on the tires put on the car. Have they ever heard of things such as radar detectors? Plus, you are absolutely correct, I’m sure there are multiple owners who switch from run flats to regular tires. Is it really that big a deal to install a 12 v socket on all cars produced.
Old Jun 1, 2022 | 02:11 AM
asdf's Avatar
You're absolutely right.
If this were a beat-up, hand-me-down car, I would think nothing of splicing a wire to the fuse box and then drill a hole for the 12 V cigarette lighter. All probably in 1 hour max.
No big deal at all.
Old Jun 4, 2022 | 07:13 PM
c4004matic's Avatar
17 E43; 21 GLS580
In cocoa
Thanks for the heads up, perfect fit👍
