EQS EQS (V297) sedan
Minor but deeply annoying problem
Old Sep 8, 2022 | 07:01 PM
RobotGuyPA's Avatar
EQS 580
So, I have a non-white / non-european first and last name, which my EQS butchers when it says "Good morning / afternoon" as I'm starting the car and it brings up my profile. Is there any way to "teach" it the right pronounciation? Or just turn that off...
It happens to mis-pronounce my name in the way that annoys me most.
Old Sep 8, 2022 | 08:01 PM
Utopia Texas's Avatar
2019 SL550/2023 EQS 580 SUV
Have you tried Robot Guy? 😊
Old Sep 8, 2022 | 08:14 PM
c4004matic's Avatar
17 E43; 21 GLS580
Nope but you can turn it off. I have an ethnic name too but I have thicker skin. Plus, its pronounced differently in the 3 languages where its common and it even has different spelling permutations! It's a dumb machine, at least its programmed to acknowledge you
Old Sep 8, 2022 | 09:53 PM
E55Greasemonkey's Avatar
This place is a joke.
Can you change the spelling to change the pronunciation?
Old Sep 8, 2022 | 10:21 PM
avilent's Avatar
Tesla Model S
My EQS also butchers my French name
Old Sep 8, 2022 | 10:28 PM
Typical of the German mind set the EQS can probably pronounce every word in the German dictionary…..
Old Sep 9, 2022 | 12:10 AM
RobotGuyPA's Avatar
EQS 580
I will dig around to see how to turn it off. Thanks!
Old Sep 9, 2022 | 12:42 AM
Diesel Benz's Avatar
I'd take the "Robot Guy" proposal seriously, or half seriously. Does the EQS pronounce incorrectly your first name as well as your surname? For simplicity I've changed my profile name to my first name only anyway. If that is not sufficient, change it to some reasonable nickname.
Old Sep 9, 2022 | 01:11 AM
bishop64's Avatar
2021 S450 4Matic
Change the first name to ''BMW'' and see if it can pronounce it correctly.
This should annoy the hell out of Hey Mercedes Voice Assistant...lol
Old Sep 9, 2022 | 01:37 PM
chaddoc's Avatar
S560 4matic
So, how to we turn off the greeting?
Old Sep 9, 2022 | 02:10 PM
c4004matic's Avatar
17 E43; 21 GLS580
Try using hey mercedes. If not its somewhere in the systems settings menu. Not too hard to find.
Try Turn off personal message . I also think it pops up when its says it at start up.
Old Sep 9, 2022 | 02:29 PM
chaddoc's Avatar
S560 4matic
I'll try "hey mercedes." I've not been able to find this in the systems settings menu.
Old Sep 9, 2022 | 02:42 PM
hlothery's Avatar
Veteran: Army
Go into the settings menu, under voice assistant, select more settings, then uncheck profile activation. The voice welcome, which I eventually found annoying, will cease. Everything else works fine. You can easily restart it by checking profile activation again, if you wish.
Old Sep 9, 2022 | 03:20 PM
c4004matic's Avatar
17 E43; 21 GLS580
Just checked, when the car greets you, on the upper right hand of the screen there is a pop up to turn it off. Be quick since it only lasts as long as the greeting!
Old Sep 9, 2022 | 03:28 PM
hlothery's Avatar
Veteran: Army
That pop-up unchecks profile activation, in the menu described above. That's actually how I found it.
Old Sep 9, 2022 | 05:35 PM
chaddoc's Avatar
S560 4matic
Thanks! That works.
