EQS EQS (V297) sedan
EQS outside A/C noise
Old Sep 9, 2022 | 06:32 PM
Fyrcity's Avatar
EQS 580
My EQS makes a lot of outside noise when the A/C is running. You can also hear some noise with a little vibration inside as well. I'm not sure if this is due to the HEPA filter or not, but it seems louder than it should. It's been pretty hot in CA lately, but the air quality isn't bad. Is this normal?
Old Sep 9, 2022 | 08:51 PM
c4004matic's Avatar
17 E43; 21 GLS580
It can get pretty loud outside. But its not the AC fan its the battery cooling system. If its hot enough it will also run when the car is off. You will also hear full tilt when charging on a fast DC charger.
You should barely hear it inside. When the AC fan is at full speed it can be also quite "sonorous". In really hot conditions they both will run at the same time. If you want to have utter silence when you get in the car on very hot conditions use the pre-entry conditioning if you set it to15 minutes pre entry. When you get there the car will be a temple of silence at perfect temp. It will however cost a little range in the process unless its plugged in.
Old Sep 10, 2022 | 11:06 AM
DaleW's Avatar
EQS 450
I hear the same noise which seems to be normal with the EQS.
I also notice what sounds(outside) like a motor when in D or R with the car not moving. The sounds stops when placed in N. Any ideas?
Old Sep 10, 2022 | 02:24 PM
eqs's Avatar
eqs
EQS 580 4MATIC
The car is supposed to make that noise to alert pedestrians.
Old Sep 11, 2022 | 10:05 AM
c4004matic's Avatar
17 E43; 21 GLS580
Its white noise up to 30 or so. To me it souds like "shhhh"
Old Sep 11, 2022 | 03:37 PM
buddy4406's Avatar
P90D
Does anybody know if the sound can be disconnected or turned off. My neighbors Audi makes a similar sound and it's horrible.
Old Sep 11, 2022 | 04:00 PM
c4004matic's Avatar
17 E43; 21 GLS580
You can simply disconect the front and rear bumper mounted speakers. Which is not recommended and illegal since that noise is mandated. I really dont see the issue since its completely unheard with the windows up. The reverse Beep Beep is still audible though. If you disconect the speakers the beep is also eliminated.
Old Sep 11, 2022 | 05:31 PM
wings1969's Avatar
2022 EQS 450
The sound and Reverse beep are controllable in the menus.
Old Sep 11, 2022 | 05:43 PM
c4004matic's Avatar
17 E43; 21 GLS580
Nope. Not the outside Beep, nor the low speed white noise.You can turn off the arrival tada noises but not the mandated white noise.
Old Sep 11, 2022 | 05:52 PM
wings1969's Avatar
2022 EQS 450
I beg to differ, I have reduced the Reverse beep several time from 5 to 1. No time now but will eventually find and screenshot for the forum.
Old Sep 11, 2022 | 06:10 PM
c4004matic's Avatar
17 E43; 21 GLS580
That is the inside sound that comes from the radio. The outside is unaffected.
Stand outside while someone reverses the car for you.
Old Sep 11, 2022 | 06:31 PM
Newbyloub's Avatar
2018 S560; 2022 EQS450+
Thank you, thank you, thank you‼️
Screen shots extraordinarily helpful over trying to unravel manual prose.
Old Sep 12, 2022 | 05:47 PM
wings1969's Avatar
2022 EQS 450
C400,
I hate when I am wrong as my wife reminds me everyday. You are correct in that you can control the volume in the menu in the car but not outside.
Old Sep 12, 2022 | 05:57 PM
HAILERS2's Avatar
Presently 19 S560 SEDAN, 2014 XK, SOLD GLE 450e
That battery cooling fan running when 'it's too hot' is a bit of wonderment for me.
Here in Texas, the Tesla battery fan ran, it seemed, all the time because we don't have a Mediterranian climate. Even in the garage it ran. The EQS not so much but it's been a lot cooler the last two weeks here. Just in the lower 90's..
. So if it runs a lot, then that means the battery is draining which in turn means I have to plug the car in and use more electricity.
Old Sep 13, 2022 | 07:48 AM
hlothery's Avatar
Veteran: Army
I live in San Antonio, and I have never heard the cooling fan running in the garage when the car is off and locked. The fans come on immediately if I unlock it to unplug, or to get in to go somewhere, but turn off again as soon as I lock it. So, if they are running, they are very quiet. I haven't noticed any battery drain in the 9 months I've owned my car. Keeping the car locked in the garage also prevents the interior lights, which stay on quite a while if unlocked, from draining the 12v battery.
Old Sep 13, 2022 | 12:47 PM
HAILERS2's Avatar
Could be my gargage on a 101* day, gets near that same temp inside my garage is My problem.
Old Jan 22, 2023 | 08:49 AM
LovinMercedes's Avatar
2026 Mercedes CLE53A4 AMG Cabriolet and 2025 MAYBACH EQS680V4
Does anyone have a screenshot of where this setting is?
Old Jun 30, 2024 | 06:25 PM
hangulo's Avatar
EQS580
I had the same problem on my EQS580 (noise and vibration inside) its the AC compressor, you can turn off the AC and the noise/vibration goes away..... looks like this is only a problem when the temp outside is above 100F and you set a differential temp inside of 20 degrees or more
Dealer said it is normal given where the compressor is mounted, etc, etc
Old Jun 30, 2024 | 07:03 PM
MB37's Avatar
23' EQS AMG
Go test another EQS on the lot, and if it sounds the same, your dealer is right. Based on my experience and talking to other MB technicians, MB dealerships will typically blow you off first until you can prove it otherwise. Sorry, no puns intended. Don't give up. Go to another MB dealer if you have choice.
Old Jul 30, 2025 | 03:51 PM
eggyacid's Avatar
ML-350, Audi Q7, Ford Taurus
Im experiencing the same issue with my EQS 450 SUV. Not super hot in Texas yet probably in the low 90s and I can hear the fan and feel the vibration thru the steering wheel. Turning off the AC/FAN completely does stop it. Dealer said it can't reproduce as it doesn't happen every drive, it's only after few errand stop and go then it will start.
File Type: mov
