EQS EQS (V297) sedan
Transponder Placement
Old 11-07-2022, 12:44 PM
TrekRider's Avatar
EQS 580
No joy on placing the transponder here. I had the same problem in the Teslas I owned. Any suggestions?
Thanks!
SaffsDad (01-18-2023)
Old 11-07-2022, 12:56 PM
bgrewal's Avatar
EQS580
Thanks!
If you look at the windshield from the outside from Passenger side. You will see a rectangle to the right of the mirror few inches down. Place it in there. I had the same issue. Hope this helps. You cant see the rectangle from the inside.
Old 11-07-2022, 01:01 PM
TrekRider's Avatar
EQS 580
Ok, thanks! I'll try that.
Also this...
Old 11-07-2022, 01:03 PM
Newbyloub's Avatar
2018 S560; 2022 EQS450+
Sure - move it down. Test it in a lower position.Locate the correct position for the tag — the upper center portion of your windshield behind the rearview mirror, at least 1 inch to the right of the mirror and ...
[img]file:///C:/Users/Louis/AppData/Local/Temp/msohtmlclip1/01/clip_image001.jpg[/img]
Old 11-07-2022, 01:23 PM
ua549's Avatar
Check your windshield from the outside. There should be 2 slightly darker rectangles, one high and one low, where a transponder will work. That is the way it is on my W213. Excuse the reflections in the pic. It is the best I could do because the areas are designed to be almost invisible.
Old 11-07-2022, 05:58 PM
TrekRider's Avatar
EQS 580
There is only one location on the windshield that looks remotely possible. If I had to ride as a passenger frequently, this would drive me crazy. I'm missing something.
taybae (11-11-2022)
Old 11-07-2022, 06:23 PM
ua549's Avatar
I have an EQS SUV manual and in the Light and Visibility section on page 173 the radio transparent areas are shown.
Old 11-07-2022, 06:25 PM
Newbyloub's Avatar
Look at your last photo - Move the transponder 2 - 2 1/2" to the left, drop it an inch or so. Go test it.
I have ridden as a passenger with such a location for tens of thousands of miles, and it's never bothered me one bit.
Old 11-07-2022, 06:30 PM
c4004matic's Avatar
Received 1,103 Likes on 727 Posts
17 E43; 21 GLS580
Shine a light on the winshield sideways it will reveal the "hole". Check amazon for a trans ponder cover. They are cheap and cover up the horrible white box.
Old 11-07-2022, 07:09 PM
Newbyloub's Avatar
People are funny - the white box doesn't bother either of us - would never spend $$ to cover it.
Old 11-07-2022, 09:06 PM
TrekRider's Avatar
EQS 580
The picture I posted above shows that as well. However the transponder doesn't work in that location. And there is nothing showing by shining a light source on it from the outside. I'm posting a new photo with the only area showing is where I have it mounted now. My wife got in the car and said WTF is that? I said not to worry, you'll get used to it after tens of thousands of miles.
The view of this photo is from the top looking down. I can't see any other place it can go.
I live in Indiana and front plates aren't required. Has anyone ever put a transponder on a front plate?
c4004matic (11-07-2022)
Old 11-07-2022, 09:44 PM
Newbyloub's Avatar
I’m pretty sure I’ve seen some on front bumpers -
you could check with the issuer of your unit.
My experiences have all been with either an RX Lexus or our ’18 S560. I don’t expect to ever be driving my 450 on a toll road.
Old 11-07-2022, 11:44 PM
c4004matic's Avatar
17 E43; 21 GLS580
For me its worse than (insert largest bird you can imagine) leaving a turd on my widshield. Why does it have to be WHITE AND HUGE. Many systems elsewhere have a credit card type transponder. The I PASS is horrible. I know first world problem....
Old 11-08-2022, 07:37 AM
Newbyloub's Avatar
Originally Posted by c4004matic
For me it’s worse than (insert largest bird you can imagine) leaving a turd on my widshield. Why does it have to be WHITE AND HUGE. Many systems elsewhere have a credit card type transponder. The I PASS is horrible. I know first world problem....
Human nature is a wonderful thing ‼️
Instead of me complaining about a “turd,” I see a super convenient tool that allows us to create drive right on through without stopping! 👍😃👍
Old 11-08-2022, 09:04 AM
TrekRider's Avatar
EQS 580
I agree with you 100%. This style is at least 15 y/o. But then I find Mercedes somewhat to blame also for this erroneous diagram.
Old 11-08-2022, 09:21 AM
ua549's Avatar
That diagram exactly matches the W213 layout. What is wrong with that diagram?
Old 11-08-2022, 09:28 AM
Newbyloub's Avatar
And the 222
Old 11-08-2022, 10:08 AM
c4004matic's Avatar
17 E43; 21 GLS580
This is what I use.
Nice and stealth. Makes the eyesore disappear.
taybae (11-11-2022)
Old 11-08-2022, 10:30 AM
TrekRider's Avatar
EQS 580
This is what I use.
Can you take a picture of where it's located on your windshield?
Thanks!
Old 11-08-2022, 10:32 AM
TrekRider's Avatar
EQS 580
The transponder doesn't work in the location next to the mirror.
Old 11-08-2022, 10:48 AM
c4004matic's Avatar
17 E43; 21 GLS580
Its worked perfectly for me. It has to be within the insibke window area as shown above.
Old 11-08-2022, 10:49 AM
c4004matic's Avatar
17 E43; 21 GLS580
this is exactly how you find the RF window next to the mirror.
taybae (11-11-2022)
Old 11-08-2022, 10:50 AM
TrekRider's Avatar
EQS 580
Thanks. So is that below the area where the windshield is sunshaded? (About 3" from the top)
Old 11-08-2022, 10:51 AM
c4004matic's Avatar
17 E43; 21 GLS580
Thanks!
This IS NOT
Old 11-08-2022, 11:51 AM
c4004matic's Avatar
17 E43; 21 GLS580
It is about 3in from both the top and, the mirror housing
Quick Reply: Transponder Placement
