EQS EQS (V297) sedan
Heater not functioning
Old Dec 18, 2022 | 03:20 PM
Soulman's Avatar
Range Rover Land Rover
I turned my Pre Entry Climate Control app on 10minutes before I leave, but when I got in the car this time it was cold. there was no heat and the fan was barely running no matter how high I toggled the temp scroll. I put it on Defrost and the fan volume sounded normal but no heat just cold air was being pumped. I've tried over the last 3 days but no difference. The seat warmers function normally, thank God! waiting. the Service Dept can't get me in until Jan 3 UGH!
Old Dec 18, 2022 | 05:46 PM
hlothery's Avatar
Veteran: Army
The fan does have it's own toggle, to adjust the algorithm for how hard it blows. Instead of just raising the temp, try raising the intensity of the fan itself by touching the fan symbol on the right side, it has like five levels. Also, if your AC system is not set to Auto, I have found that to be the most efficient setting. Hope this helps.
Old Dec 18, 2022 | 06:42 PM
c4004matic's Avatar
17 E43; 21 GLS580
I went through the same thing once. Next tme I turned the car on I made sure it was on auto and its been fine since. Never figured it out.
Old Dec 19, 2022 | 05:33 AM
Diesel Benz's Avatar
I thought in pre-entry climate control mode the HVAC fan was always working at a fixed speed, just like it works on older cars with fuel burning AUX heaters. Still strange if the electric heater had no influence to the cabin temperature.
Old Dec 19, 2022 | 03:03 PM
Soulman's Avatar
Yes, I also separately adjusted the fan speed manually, as well as letting Mercedes Me adjust the heat up but to no avail.
Diesel Benz. I always go to the Mercedes app and "activate" it for my desired levels.
Old Dec 19, 2022 | 03:52 PM
The EV is different from the hybrid then if you can adjust the HVAC fan speed for pre-entry air conditioning. The on-line EQS manual does not describe this option (from the car or the app) but it must be there if you say so. On the hybrid the fan speed is fixed even if one sets it manually to any speed when the car is "on".
Old Dec 19, 2022 | 04:33 PM
hlothery's Avatar
Veteran: Army
I don't use the preconditioning. I might ask that you try not using it, just get in the car, turn it on, set the temp and fan, turn on Auto, and see what happens. If that doesn't work, the heater is definitely malfunctioning. In that situation, mine produces almost instant heat, and the battery tanks at the same time!
Old Dec 20, 2022 | 01:20 PM
Soulman's Avatar
Yes, I just tried starting heating without the preconditioner, turned on Auto, but no luck. It just barely blows air and it is defiantly cold air.
I'm scheduled for a Jan 5 service. I Appreciate everyone's thoughts!
Old Dec 20, 2022 | 09:01 PM
hlothery's Avatar
Veteran: Army
Sorry to hear....hope it's easy to fix.
Old Jan 2, 2023 | 07:21 PM
Soulman's Avatar
Follow up: Right after Mercedes pulled the Holiday graphics everything went back to normal. the passenger screen with the compass/elevation displays came back, and more importantly my heater once again functioned properly, with or without the use of Pre Conditioning.
All is good that ends well.
Old Jan 3, 2023 | 01:58 PM
hlothery's Avatar
Veteran: Army
Wow.....that's crazy, and scary! I like the Holiday decorations, but now worry about them causing glitches. Is there a way to decline them?
Old Jan 3, 2023 | 04:15 PM
Soulman's Avatar
I believe there is but I haven't delved into the manual.
Old Jan 3, 2023 | 04:28 PM
Utopia Texas's Avatar
2019 SL550/2023 EQS 580 SUV
You can turn them off but I have no idea if that stops the EQS from still receiving updates on the decorations in the background.
If you just take ten minutes and go through all the options/screens you will find out what you can adjust in the EQS to suit you….
Old Jan 3, 2023 | 05:46 PM
c4004matic's Avatar
17 E43; 21 GLS580
Go to the displays sub menu. Turn off animations or something lake that its the last option.
