Testing EA 350kW charger
Just as an aside, I had my software updated to version E329 yesterday and some functions apparently defaulted to factory. Augmented reality navigation went back to regular for one.
I had this issue at an EA site before. I was lucky enough to have a EA service Tech arrive to service the chargers. My charger was 150KW and charging at 57KW. Usually, with eco on, at this site, I get 106KW. The tech said he had to change out some capacitors and to expect the problem to be resolved when I return. Sure enough, a week later all was fine. I would suggest you call EA when you come across this issue. It seems they can do remote diagnostic and if it appears fine on their end, they will send someone out. Although a tech isn't going to show up when you're there, it helps us all out.
I read somewhere that not only is the charging company charged for the energy (Kwh), but on a fast charge, some utilities charge extra for the "surge" on the grid that fast charging causes. The article I read stated this to be expensive. The article suggested batteries at the chargers could charge slowly and then the car's battery could charge from the storage battery.
I think there is a bunch of issues, but more often then not most stations I used in the last few months had some or all of the chargers not working, working slow, or did nor recognize my car. Most times a call helped, but not always.
I would imagine paying the "surge" charge or upgrading the stations with battery packs will be very expensive, but if this doesn't get fixed, electric cars will be limited to people that have access to their own chargers and limit their driving to half of the range so that they can return.
Well, EA and CP has some issues. I have about 9 charging sessions which still show pending (Not charged yet). A couple are back in October. Including the slow session I mentioned which took an hour. The hour session convinced me to install a charger at the house sooner than later. Now that I have, it's been amazing. Also, if EA doesn't recognize your car, start the charge from the EQS navigation menu. I've moved on to other chargers before learning this trick.
I need to learn how to do the charge from the NAV screen. The phone rep from EA walked me through it once, but my memory is not that great and forget how to do stuff like that if I don't do it often. As it has been happening too often, perhaps I should learn again and commit it to memory.
You just described me. And, I knew when I ordered my car it would be this way. No problem. For long distances, it’s either my wife’s Rx Lexus or our ‘18 S560, that has just reached 25,000 on the odometer.
Re: preconditioning I hope MB will update their software to follow Tesla and Porsche - when selecting a charging station in Navigation it automatically turns on preconditioning. As far as I can tell now, the only way to have preconditioning in the EQS is to have the Navigation select the particular charger you want (you can delete the charging stations you do not want in the menu).
Re: knowing it is prewarming - if you select to display the current Wh/mi usage, it suddenly increases 5-10 minutes before destination to do the prewarming. It will also drop your estimated range quite precipitously in cold weather...
