Charge loss while parked
Does it get better? What have others experienced?
Connectivity from/to the car to/from MB servers does consume some power but NOT from the high voltage battery when the car is parked. The 12 V battery provides power to these control units.
I don't know what caused the sudden 1-day drop from 37% to 34%, but I was pleased that it didn't continue.
Definitely bring it in if you are not getting close to maximum range for 80%.
Another possibility is that the car's SOC charge calculation is incorrect.
What were the circumstances of the charging? How do you know how much you put in? Were you at a public charger or does your wall charger give you this information?
Not sure this applies to you but I read an article recently(either Motortrend or Car & driver) that tested several EV's and it that most lose charge just sitting and not being used. They stated that with an EV the vehicle conducts routine conditioning (not sure what) which draws down the batteries.
Any battery loses charge over time even if completely disconnected from the outside world. For lithium batteries this is insignificant. What sort of figures did the article talk about? 1% a day, week, month, year? Makes a difference!
I'm not sure if the high voltage battery control unit actually did some periodic checks. I would assume more like hard wired leak monitoring but in any case, nothing that would cause noticeable battery drain on an EV with a relatively huge battery.
The 12 V battery has a lot of continuous load. Nothing like the starter on an ICE car but significant compared to the total capacity. The alarm system is on when parked (of the order of 40 mA power consumption), the remote access modem is on, keyless go is active etc. All these are a significant power drain if e.g. the car was not driven for a month.
The 2% loss for the high voltage battery that is being discussed, must have some other explanation than normal periodic tasks or battery internal leak. Could be timed (unintentional) cabin pre-conditioning, the car detecting the key and triggering heat seating. Perhaps battery cooling after charging session although this should not be needed when charging at home with low current (cooling or heating).
