Second USB-C for music while dashcam USB-C is plugged in.
Eg
1. If the USB-C flashdrive for dashcam is removed, does the USB-C flashdrive for music work?
2. Does the USB-C flashdrive for music work in other USB ports (in front centre console, in phone compartment under the centre armrest)
If it doesn't then there is something wrong with the drive.
If it does then the Dashcam drive is taking priority over the mp3 drive and you have to go into USB menu to select it as the drive you would like to listen to.
Eg
When I get some time I'm going test your suggestions. But I can say that when I had them both pugged in next to each other, the system recognized only the dashcam drive.
Eg
Also, other than mp3, are other music file formats readable?
Have you tried to use those for either flash drive? I mean, dashcam flash drive in one of the centre console ports and the music flash drive in one of the centre armrest ports?
One thing you might try (perhaps at a later stage when other options have all been exhausted) is get one of these USB-C splitter so the dashcam flash drive and the music flash drive can both be used on a single centre console port.
https://www.unitek-products.com/prod...charge-adapter
Contacted MB. They could not help.
My solution is:
Buy a 512 GB or a 1TB USB
Copy your songs on the USB
Use same USB for dashcam.
Play the music and at the same time the dashcam will record
It has work for me.
I removed the USB and check on my computer. A folder is automatically created for the dashcam recordings.
Hope this helps
