EQS EQS (V297) sedan
Yes - the 12V battery is automatically recharged by the high-voltage battery
Old Jun 29, 2023 | 10:12 AM
W205C43PFL's Avatar
Originally Posted by Diesel Benz
It could be the SW version of other control units, those that take care of battery charging (diag tool needed for that additional info).
That is probably true, I wonder if that update (forgot which version but it stated something along the lines of Update the module responsible for future module updates) was the prerequisite?
Old Jun 29, 2023 | 10:35 AM
GreasedFolgore's Avatar
2025 Maserati Grecale Folgore and 2024 Jaguar F-PACE SVR
Maybe the battery is bad and won't fully charge. They usually get really hot when that happens so maybe the BMS also monitors temp and stops charging it. Just guessin' though... should probably let the dealer diagnose since we're not even supposed to open the hood on these vehicles and would suck to void your warranty just to put a volt meter on it.
Old Jun 29, 2023 | 10:43 AM
W205C43PFL's Avatar
I wonder if the alternative of plugging in a scanner in the OBD2 port will also work or if there is a menu to check the battery voltage in the infotainment system?
Old Jun 29, 2023 | 10:45 AM
W205C43PFL's Avatar
Found what I was referring to: https://cimg3.ibsrv.net/gimg/www.mbw...2139d9fe3.jpeg
Old Jun 29, 2023 | 10:53 AM
BMS definitely broadcasts the high voltage battery status over CAN bus so maybe... I just have a regular OBD2 reader though and can't see that info. You'll need to get something like what Bjorn uses:
Old Jun 29, 2023 | 11:07 AM
W205C43PFL's Avatar
https://youtu.be/NA1Ygc19Qxk
I see.
Old Jul 7, 2023 | 05:56 PM
  #32
Radman991's Avatar
2005 SL 500. 2015 S550. 2016 GLE400 2018 S560
Follow up to my 23 eqs 580 sedan which has been sitting in my garage since mid May. After 4 weeks the app still displays the 12 v battery as partially charged. Went to dealer today who stated unequivocally not to worry, car senses the battery is low and will maintain it so it doesn’t become fully discharged, as long as hi voltage battery remains charged( my SOC is 77%). I asked why doesn’t it fully charge it and was told it may not fully charge it but will keep it charged enough so it won’t brick the car. I’m not planning on using the car till the fall when I return to Florida so I hope he’s right.
Old Jul 7, 2023 | 07:20 PM
  #33
W205C43PFL's Avatar
Like you said hopefully it is alight, what version of software is your car running right now?
Old Jul 7, 2023 | 08:07 PM
  #34
hlothery's Avatar
Veteran: Army
Interestingly, I just had my car in for the three software safety recall updates. During this period, the car sent me messages that windows were open, the trunk was open and the ignition was on. The invoice also showed that the dealer had it hooked up to a battery charger for the 12V battery while doing the updates.
Old Jul 7, 2023 | 08:44 PM
  #35
Radman991's Avatar
I’m on version E329.xx. I even asked if updating to E330 would help and the reply was we don’t know.
Old Jul 7, 2023 | 09:01 PM
  #36
W205C43PFL's Avatar
Then if they don't know they should update it, I only heard positive feedback on the forums with E330.xx as it provides bug fixes and even quality of life improvements.
Old Jul 8, 2023 | 10:59 AM
  #37
Radman991's Avatar
I agree. Problem is my car in garaged in my Florida home and I summer in RI. I bought the car in RI (7th Mercedes from them) so I great service from them. The times I’ve had to use the dealer in north palm beach hasn’t been so accommodating.
Old Jul 8, 2023 | 11:10 AM
  #38
W205C43PFL's Avatar
I see, not all dealerships are created equal.
Old Jul 8, 2023 | 11:15 AM
  #39
jcapotos's Avatar
2025 Porsche Cayenne S Hybrid + 2023 EQS 580 SUV
Talking
I agree with your comments on North Palm MB. Every time I bring car in for service they do an inferior job. My first annual tune up the mechanic did not mount the engine cowling properly and caused vibrations. I had to bering car back to fix it. The second annual tune up, when driving home I am stopped at a light and realize smoke is coming out from under my hood! I bring it back and apparently the mechanic didn't turn off the oilpump before removing the nozzle and spilled oil all over the engine. They didn't have the honesty to tell me about this issue until I brought the car back. Then I had to wait 45 min while they steam cleaned my engine...Not happy. I book my third appointment (and loaner car) for a recall update and they tell me I don't have an appointment. I convince them with all of the text messages ands emails confirming then appointment. Based on that they agreed to service the car and then they tell me they don't have a loaner. I explained to them that is THEIR problem and dal with it....I got my loaner . That was the last strike for me, as I will be servicing my car at West Palm.
Sorry for the long story....just had to vent...
Old Aug 19, 2023 | 05:12 PM
  #40
Radman991's Avatar
Sorry to beat a dead horse but…… Car has been sitting in my Florida garage since May. I’m in RI. No trickle charger. Was told hi voltage battery will maintain 12v battery by dealership. Have monitored status thru app and was always “partially charged”. Downloaded latest Mercedes me app and status went to Low(red letters). Briefly went to critical. Got email warning I should charge the 12 v battery. No guarantee car will start. Just happens I am flying to Florida as we speak to check up on car and house. Called dealer. They have no idea why battery is not being maintained as they even printed out a sheet outlining how the hi voltage battery will maintain the 12 v battery in storage mode. Will arrive at house later tonight and see if car starts. Meantime dealer told me to put it on a trickle charger.
Old Aug 19, 2023 | 05:31 PM
  #41
finlayson's Avatar
No Mercedes yet
It's strange that some people (e.g., I) have been seeing the 12V battery getting automatically recharged by the high-voltage battery when the car is parked for a long time - and others have not. It would be nice to get some definitive information from MB about the reason for this (e.g., software versions). But, as usual, we can only speculate, because nobody from MB ever posts to this forum :-(
Old Aug 20, 2023 | 01:40 AM
  #42
Diesel Benz's Avatar
You don't mention the high voltage battery SOC. I assume it has plenty of charge as you don't mention it. At some point I'd assume the high voltage battery would get priority over the 12 V battery to protect the part. I have not seen the latest function descriptions for this but would expect automatic 12 V battery maintenance working down to at least 20 SOC of the high voltage battery, if it works in the first place.
I though you already have been away from the car for a long time. If the car did not charge the 12 V battery at all, it would die after about a month if not charged and if the car was not set for hibernate mode. So I assume your car has been charging the 12 battery for some time. Odd if not any more.
Old Aug 20, 2023 | 04:21 PM
  #43
Radman991's Avatar
I put the car in storage in my air conditioned garage starting with a SOC of 82% in May. For the past 3 months the 12v battery went from fully charged to partially charged while the SOC went down to 73%. Thursday of this past week the 12v battery went to Low and for about 30 minutes, critical. I arrived at my house last night and drove the car for the first time hoping to charge the 12v battery. Good thing was car started right up. Tire pressure was 40 lbs and gave a warning so I put air in them. Today the 12v battery reports as charged. The over air sound software update won’t load, apparently because it’s stating battery is not charged enough. I will let it sit for a few hours and see if car resets so that I can download that software.
Old Aug 20, 2023 | 04:24 PM
  #44
Radman991's Avatar
On another note, my car was built in July 22 and was delivered to me in mid December 22. So it sat for 5 months without being driven. I wonder how Mercedes kept the 12 v battery up to charge during those 5 months.
Old Aug 21, 2023 | 01:43 AM
  #45
These cars have a "deep hibernation mode", I cannot remember the correct name but during transport from the factory and during other long periods of long parking this mode is activated. I'm not sure how low the consumption then goes and if the car accepts 5 months parking without charging but we have machines at home that are operated only for about a month in a year and they survive 11 months without battery charging. These tools have a main switch that cuts off all current consumption (and a 140 Ah battery).
Old Sep 18, 2023 | 12:49 PM
  #46
Radman991's Avatar
Follow up to my car sitting in my Florida garage for the summer. As I said I went to Florida a month ago and drove the car to charge up the 12v battery. Everything worked fine. No warnings. Car now has been sitting unused for a little over a month since I went to Florida. Left it this time at 65% SOC and 12v battery as charged. 12 v battery has gone from charged to partially charged on 3 occasions. Every time within a day or so the 12v battery went back to fully charged state. The SOC has stayed rock solid at 65%. Don’t know what happened but now it’s working as advertised. Previously the SOC went down at least 1% each week and 12v never fully recharged. Not sure if something in the car was active all along causing a slight battery drain but it seems to be working as designed now.
Old Sep 18, 2023 | 03:16 PM
  #47
Trekguy77's Avatar
Cadillac ELR. EQS450+
Thank you for the update.
It is reassuring to know
