EQS EQS (V297) sedan
Tire information display
Old Sep 27, 2023 | 06:36 PM
GreasedFolgore's Avatar
2025 Maserati Grecale Folgore and 2024 Jaguar F-PACE SVR
Oh forgot to add that you need to be careful not to accidentally swipe up while swiping left and swiping right at 80 MPH on the interstate or you'll mess up your HUD and have to figure out how to fix that at highway speeds too. Thank God it makes me pull over to type "k brt" though or I'd definitely get distracted and have a wreck.
Old Sep 28, 2023 | 03:53 PM
LAZARU5's Avatar
2025 E53 Hybrid
Originally Posted by Crito
Yeah, you just hit the home button on left side of steering wheel, swipe left several times and then try not to hit the home button again to select but press the same place you were swiping or you'll have to start all over. Then after you check the pressure, press home again, swipe in other direction several times to get back to the normal screen, try not to hit home to select, and press the swipe area. It really couldn't be any simpler.
When you want to return to your normal cockpit screen after checking the tire pressure on the Service display, you can simply hit the "back" button to the left of the "OK" button to return to the previous screen you were using. There is no need to press home again and swipe back to your normal cockpit screen.
