EQS EQS (V297) sedan
Low coolant warning
Old Oct 20, 2023 | 08:12 PM
genechen22's Avatar
EQS 580
Low coolant warning
I had the Low Coolant warning come up and I checked and it's pretty low. What would cause Coolant to be used up and go low? I have less than 5k miles on my EQS.
Old Oct 22, 2023 | 02:53 PM
hlothery's Avatar
Veteran: Army
I would have my dealer search carefully for eny evidence of a leak. This sounds like a dealer issue.
Old May 8, 2025 | 03:28 PM
W205C43PFL's Avatar
What was the fix OP?
Old May 14, 2025 | 07:47 PM
z0lt3c's Avatar
23 EQS 580 SUV
This is not uncommon, had the same thing happen but at higher mileage. There should be two coolant tanks, sometimes they do not balance out perfectly, sometimes a little air can get into the system. Dealer should top off, under warranty, and then monitor to make sure the light doesn't come back on.
