EQS EQS (V297) sedan
Mercedes Wallbox
Old Mar 16, 2024 | 10:49 PM
  #101
jjcarter's Avatar
23 EQS 580
Thanks. What if you want to charge it to 80% and start at 11pm? Do you just put a start time?
Old Mar 17, 2024 | 07:55 AM
  #102
hlothery's Avatar
Veteran: Army
Please let me know how this works. The only problem I've had with the ChargePoint is that when you schedule a charge to start later, the wallbox asks the car if it wants to charge through a series of clicks every 15 minutes or so until the charge starts. I had noticed the clicking while in my garage working. This worried me, although the ChargePoint folks said no worries. I stopped doing the scheduled charges and just let it finish, then unhook it the next day. Now I'm doing shorter charges (based on all the talk about short cycles being easier on the battery on this forum), and it is not a problem anyway. Now it finishes before I go to bed.
Old Mar 17, 2024 | 10:17 AM
  #103
jjcarter's Avatar
23 EQS 580
My concern is what happened to scheduled charging that was in this video at the 53 second mark. This would be the option if you wanted to charge during off peak hours and just leave the charger plugged in before you go to bed. Mercedes customer support has no idea and is no help.
Old Mar 17, 2024 | 12:03 PM
  #104
23-EQS580-SUV's Avatar
2023 EQS 580 4Matic SUV
I would plug it in and select one of my preset paused time that I set up and it will automatically charge outside the paused time.
For example if I come home at 5PM and plug it in and it won’t charge till after 9PM till it reached 80%. The only problem is once it reached 80% and stop charging the timer on the app still running.
So it might take 7 hour to charge from 20-80 but if you don’t unplug it the timer will continue to run but not charging. Timer stop when you unplug or set another pause time when you know what time it will finish charging to when you’re able to unplug it.
i know it take about 7 hours to charge from 20-80% but if you don’t unplugged it the timer on the app won’t stop but not charging. The leds on the wall charge still blue.
You just have to play with the setting. Your EV will make a series of clicking each time you make a change and saved your setting. That is normal.
like I said the Mercedes wall box have very limited setting not like the ChargePoint home flex.
Set state of charge.
Set the time you don’t want it to charge. My peak are 4PM to 9PM.
Old Mar 18, 2024 | 08:32 AM
  #105
hlothery's Avatar
Veteran: Army
Yea, I know all that. What I'm saying is that, while it is waiting to charge at the selected time, my charger would constantly emit a series of clicks, every 15 minutes or so, for hours and hours. Maybe that doesn't worry you, but it did me, so I stopped scheduling charging. I'd be interested to know if the new Mercedes Wallbox does that. I know how to schedule a delayed start time.
Old Mar 25, 2024 | 01:44 PM
  #106
sunnyk777's Avatar
EQE350X4
Hey all, reading through the thread, I understand that to achieve 9.6kW, a 40A charging station is needed. Per the Walbox's (EVBox Livo) specs, max output is 32A, so I can only expect 7.7kW from the Wallbox correct? I thought I'd confirm as I would think the Wallbox would support the max 9.6kW. Am I missing something? Thanks.
Old Mar 25, 2024 | 04:20 PM
  #107
hlothery's Avatar
Veteran: Army
You have to have a 50A circuit in order for the wallbox to provide 9.6kW at 40A. You cannot use all the amperage in the circuit safely, and we set my Chargepoint box at 40A. But, with the max output specs of your box, I believe you are correct. You will be charging at 7.7kW.
Old Mar 29, 2024 | 11:31 AM
  #108
eqs_fun's Avatar
EQS 580
Originally Posted by 23-EQS580-SUV
that should work fine but keep it short as possible.
So I'm in a similar boat as many others here. Just got a free Wallbox with my EQS. Currently have a NEMA 14-50 outlet setup a couple of years ago, as I was using it for charging my previous EV (which came with a plug in charger that I need to return when my lease is up). Reached out to Qmerit around installing the Wallbox and they want $800 to install it (which I think is high).
If I were to order this 4-prong cable, I assume green is ground and white isn't used. Does it matter if red connects to L1 and black to L2 (or vice-versa)?
Old Mar 29, 2024 | 11:43 AM
  #109
ILoveNY's Avatar
GLC EQB GLS C300 convertible
can the wallbox be used outdoors eg in a carport situation?
Old Apr 4, 2024 | 11:14 PM
  #110
LovelyDay's Avatar
EQS 450 SUV
No Confirmation Email for Free Wallbox
I submitted my request for the free wall box 3 days ago and received the auto response saying I’d receive an order confirmation and shipping details within 48hrs. I haven’t received anything so I thought maybe I was being scammed until I found this thread. 😂 My dealer didn’t tell me about it. That kept pushing me to Lowes to buy a Chargepoint. Anyway, did you all receive confirmation and tracking details or did the box just show up?
Old Apr 5, 2024 | 09:35 AM
  #111
Radman991's Avatar
2005 SL 500. 2015 S550. 2016 GLE400 2018 S560
I did the same thing and lo and behold my Wallbox arrived at my door within a couple of weeks. I did get a shipping notice eventually. I had my car for over a year and already had a ChargePoint flex but if Mercedes was giving the box to me free I couldn’t say no.
Old Apr 5, 2024 | 11:34 AM
  #112
teksurv's Avatar
2024 EQE 500
I also did not get an update within 48 hours. I emailed the address in the auto notification about it and had the wallbox at my door within 3 days.
Old Apr 26, 2024 | 04:59 PM
  #113
demand56's Avatar
EQS300
Wire type
what type wire you used ? Stranded or Solid?
Old Apr 26, 2024 | 07:37 PM
  #114
I used Romex 6/3 stranded wire. (3x 6 gauges with solid ground wire)
Old May 1, 2024 | 01:43 PM
  #115
sunnyk777's Avatar
EQE350X4
I am having issue when trying to access the Wallbox menu in the Connect app, rendering the inability to charge. Anyone experience this?
Old May 1, 2024 | 06:21 PM
  #116
i got the same message. I'm going to try to reconnect it when i get home. hopefully it will resolved the problem.
Old May 2, 2024 | 08:52 AM
  #117
After reconnecting the wallbox to the app it still giving me the same error message. It must be a network issue on the MB side. We both can't be having the same issue. Anyone else with MB wallbox is having the same problem?
Old May 2, 2024 | 05:57 PM
  #118
dmstl's Avatar
2023 EQS 580 Sedan
Electrician coming next week to install my March Madness MB “free” Wallbox. Hoping free doesn’t turn into a problem, so I will be following the resolution here.
Old May 3, 2024 | 09:19 PM
  #119
EQEBlue's Avatar
EQE 350 4matic
Oh, man......I wish! The 50amp 240V circuit cost me $2K to install in my garage. Is a 60 amp circuit even possible in the USA?
Originally Posted by c4004matic
Correct. However, in other countries the EQS is available with an 11kw onboard charger.
You can only AC charge at the rate the internal charger in the EQS will allow (9.6kW), no matter what the wallbox says it can deliver. My ChargePoint has been flawless so far.
This is due to voltage difference. In the US residential we don’t get the full 240V we get 208V and ‘three phase industrial is needed’ not just commercial. If you are near a Porsche passport location (that isn’t Derated) EQE/S will accept 11kW only place I’ve seen this is at Ritz in SoCal.
weirdly Tesla universal is limited to 9.6kW.
Old May 3, 2024 | 11:19 PM
  #120
trayvdo's Avatar
2022 EQS 450+
My wallbox gave the same error, what I found was if your not the main user of the app it will not let you install wallbox as an invited guest.
Old May 20, 2024 | 10:17 PM
  #121
stc1996's Avatar
2022 E350 4Matic
2 questions:
-have MB Wallbox and app says update is needed via internet. I’ve connected the box to the web but won’t update. Ideas?
-for the scheduled charge times, do I enter the don’t charge/pause time or the actual charge time?
Old Jun 2, 2024 | 03:53 AM
  #122
BayAreaBMWFan's Avatar
EQS SUV, X5 45e, Model 3, 328 Vert
We leased an EQS SUV and received the free Wallbox charger. Before I plan the install I had some questions:
1. Can the charger be used to charge non-MB vehicles (we have a Model 3, and an X5e also) It seems to be closely integrated with the MB ecosystem, hence asking.
2. Does the Wallbox come with an NEMA 15-50 plug or do we have to buy a cord.
3. I plan to share.a single circuit with the two chargers; any suggestions for a good splitter?
Old Jun 2, 2024 | 12:26 PM
  #123
1. yes, use Tesla adapter
2. No, buy a dryer cord if you want to plug in.
3. NO, if you happen to use both charger at the same time the wires will catch on fire. Don’t recommend splitting.
Old Jun 2, 2024 | 05:15 PM
  #124
Thanks.
By the splitter I mean those which share the current capacity based on a priority based citeria.
some example are:
LECTRON-NEMA-Socket-Splitter
https://getneocharge.com/products/nema-14-50
Amazon Amazon
Old Jun 3, 2024 | 12:41 AM
  #125
GreasedFolgore's Avatar
2025 Maserati Grecale Folgore and 2024 Jaguar F-PACE SVR
My Splitvolt 24 AMP NEMA 14-30 EVSE with 26 foot cable would trip the circuit breaker if used at same time as dryer so I'm not worried. A $60 Parkworld splitter works fine for me. Total cost, installed, is less than $400.
