EQS EQS (V297) sedan
Windshield and Radio Waves
Old Feb 5, 2024 | 11:04 AM
ScottM5000's Avatar
Audi ETron
Hello, I have 2 questions regarding the EQS windshield blocking radio waves (except for the two permeable zones). My golf club is in a gated community and they are updating the gate system. The new gate system requires a bar code be applied to the inside upper left corner of the windshield. My owners manual, see below, states that I should be able to see the permeable areas with an external light. I cannot see these areas with an external light. My questions are:
1) Do all EQS's (mine is a 2022 450+) have this type of windshield?
2) Has anyone placed an RFID tag/barcode on their windshield in a non-permeable position and have it work?
Thank you in advance.
Old Feb 5, 2024 | 11:37 AM
c4004matic's Avatar
17 E43; 21 GLS580
The laser that reads the bar code will penetrate the glass just fine anywhere on the windshield. If you want to test it, simply attach the bar code with tape instead of sticking it (if possible) and give a test run.
Old Feb 5, 2024 | 01:42 PM
23-EQS580-SUV's Avatar
2023 EQS 580 4Matic SUV
My radar detector and toll road transponder are on the windshield, and it worked fine.
Old Feb 5, 2024 | 03:48 PM
matts's Avatar
'23 EQS 580
Only those with the heated windshield have this coating. Not all.
Old Feb 5, 2024 | 03:55 PM
AppleFan1's Avatar
2025 EQS580
Mine does not work in the space allotted about 3-4 inches to the right of the rearview mirror. I called Ez Pass in Ohio and I was told to place the transponder in the bottom of the windshield on driver’s side. I can’t test this until late July on our next trip to near Akron, OH from Des Moines.
Old Feb 5, 2024 | 04:00 PM
matts's Avatar
'23 EQS 580
If you look from the outside with a flashlight or at just the right angle from inside you can make out the openings for the RF signal to pass through. I have my EZ pass in the opening to the right of the rear view mirror (live in Ohio, 2 miles from the toll road) and it works.
-Matt
Old Feb 5, 2024 | 04:18 PM
AppleFan1's Avatar
2025 EQS580
-Matt
My transponder was definitely in that rectangular slot. I had EZ Pass in OH send me a new transponder last year and I’m still having problems.
Old Feb 6, 2024 | 01:47 PM
bgrewal's Avatar
EQS580
There is another thread where we discussed this in detail. I too had problem with the toll transponder being read when inside the little rectangle. I put it on the sunroof and it works flawlessly.
Old Feb 6, 2024 | 01:48 PM
matts's Avatar
'23 EQS 580
I thought about that too ... does it interfere with the sun shade?
Old Feb 6, 2024 | 01:51 PM
bgrewal's Avatar
EQS580
mine does not. It’s thin enough to not interfere. Now, I used extra strong Velcro because in summer if you are parked out it will come off so I used Velcro that is good until 150 temperature or something like that.
Old Feb 6, 2024 | 01:53 PM
matts's Avatar
'23 EQS 580
I have the original EZ Pass that is square, kinda thin, about 1 inch. Which do you have?
Old Feb 6, 2024 | 02:04 PM
bgrewal's Avatar
EQS580
California FastFlex rectangular.
Old Apr 6, 2026 | 12:09 PM
Surge's Avatar
W463 G550 / C190 GTC //prev: W204 C63 507 / R170
I have the "true" heated radiant windshield and a toll transponder on the dash works perfectly fine.
Old Apr 7, 2026 | 01:58 PM
enj's Avatar
enj
MB S450 2018 4Matic; MB EQS SUV 450
I have problems using my EZpass (NY-NJ) with both of my 2023 EQS 450 SUV and 2023 EQS 450+. I believed the EZpass tag may be at fault because the two locations suggested by MB were not working most of the time. I ended up using an external tag mounted on the front license plate.
It was very frustrating.
