EQS EQS (V297) sedan
Effect of tires on range.
Old Nov 6, 2024 | 03:12 PM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
Guys, don’t shoot the messenger. See with objective eyes, don’t worship at the Ev altar…
AI Overview
Learn more…
Yes, an EV car is more likely to get stranded in severe cold weather compared to a traditional gasoline car because cold temperatures significantly reduce the efficiency of its battery, leading to a dramatic drop in driving range and potentially leaving the driver stranded if they can't reach a charging station before the battery runs out.
Key reasons why EVs are more vulnerable in cold weather:
  • Battery chemistry: In cold temperatures, the chemical reactions within the lithium-ion battery slow down, meaning less power is available to the motor, impacting range.
  • Increased energy usage for heating: To maintain a comfortable cabin temperature in cold weather, EVs need to use more battery power to run the heater, further reducing range.
  • Charging limitations: Cold batteries can also take longer to charge at charging stations.
How to mitigate the issue:
  • Preheating the car:
    Plug in your EV and use the preheating feature to warm up the battery before driving in extreme cold.
  • Planning ahead:
    Be aware of your reduced range in cold weather and plan your trips accordingly, ensuring access to charging stations.
  • Newer technology:
    Some newer EVs are equipped with heat pumps which are more efficient at heating the cabin in cold weather.
  • Electric Vehicles Aren't Ready for Extreme Heat and Cold ...
    Feb 15, 2024 — When EV batteries are being juiced up, charge-carrying lithium ions travel through a liquid electrolyte from one end o...
    [img alt=""]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAACAAAAAgCAMAAAB EpIrGAAAB7FBMVEX////////////R0dFZWVkwMDBEREQ/Pz+IiIiRkZHm5uZzc3M8PDxBQUExMTF2dnZ7e3v09PSfn596en rv7++/v78HBwdRUVH39/fq6upLS0uzs7MNDQ1jY2P5+fnf398oKCgAAADw8PAjIyPW1tYu Li6ioqJPT0/Hx8cGBgYeHh76+vrV1dUEBAQtLS3h4eEBAQFMTEz+/v6pqakyMjJra2tISEgZGRlNTU2SkpLQ0NB9fX0JCQmDg4OWlpb 8/Pxvb2/Pz89iYmKHh4c4ODjy8vJwcHCcnJympqZ/f3/4+Pju7u7Ly8u3t7fAwMACAgKamprDw8Nqamqurq49PT0iIiIIC Aja2tovLy/Nzc0KCgohISFlZWURERGJiYksLCwqKiogICB8fHyZmZlycnLo6 OjJycl5eXnFxcWPj4/29vbz8/P19fW7u7ugoKCqqqre3t6lpaXi4uLS0tLMzMzx8fFcXFyOjo5T U1Orq6vt7e0cHBzb29vGxsZDQ0MfHx+kpKRsbGxAQEAWFhYMDA xCQkLExMR0dHSbm5ttbW3l5eU5OTnCwsJJSUmNjY11dXVpaWnT 09P9/f0FBQUnJyfOzs5FRUVmZmbd3d0UFBSoqKjY2Ni2trYTExNKSkr s7OxeXl6UlJSMjIwDAwPi3mxPAAAAAnRSTlPl8gYpWaEAAAHoS URBVHgBhNGDYt0AAEbh2zOjtvvXtm17rDvW9rzVNmY9aK2MJ06 +2GQy+2cmE//JZHYwv3Dx0uUrV68drF6/cdPcwtLK2uby5cu2dpgdAnsHRyecb7rsr7q6uXvg6SVvfCRfjo Gf/AHPAAgMCg4BQsO8CZciTkCkoqKBGKJjFQdAvBEkSIkRAIFSEgD JHgaQIinVyhrSpHSOMoCMzEhJPllkSzl/AhCYKykhz13K/zMguiBVKiyScgEoLjkPSssA0qWr5VKFL0Cl63lQVQ3gK92KDpd uW0PEHWsDuHsPsNH9EGpqpbrq+oZGaJI8T0Dzg4ePHte6PAGeW kgKa4mmdZ+2tR+BDuvOru6eXg6LLvXv6wcGBvc7AkcNOfGnzsD wCABpkdIowJik7GdnwC61icOeVyg1D3CskF5wBtKllwAEv5L6w O51s/FLxkruR+CNFAAFb42fOuvduCY6DoFnghy8mZwygri+aWnmEETM SjZzddEG4FTX7ivNH4EFaXFpGQPoW4F5afUA9K8laH1j0wgmt7 a3Y6X8A+DNrLSBAew07ezs+E7ovcchWJCKjMAqDSBb+nAI9u/x0QCcEsYAPkk3if7cC7OXAK/TL9nxRU198PWbJPcVuQzQ+h1+/Dz+F/ynvRHM/gBixHIw8RbgzQAAAABJRU5ErkJggg==[/img]
    Scientific American
  • How freezing temperatures are affecting electric vehicles - Axios
    Jan 16, 2024 — How it works: While all cars are less efficient in the cold, electric vehicles are impacted more because the energy it...
    [img alt=""]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAACAAAAAgCAMAAAB EpIrGAAAAz1BMVEUAAADv7+/v7+/t7e3u7u7u7u7u7u7v7+/v7+/r6+vv7+/y8vL4+Pj8/Pz+/v7////7+/vz8/Pv7+/v7+/39/f9/f3w8PDt7e3u7u719fX09PTv7+/q6ur5+fnO2vgoNFIiIiLIyMjs7Oz29vaEou0yUJtZWVnt7e3n7 fw7a+M5ZtcjJi7s7OwuRoJ1dXUvLy/v7++1x/SCgoKQkJBTfebm7PvV1dUwMDBskOqenp5gh+hMTExUfeesrKzt 7e3x8fGRkZGDg4Pa4/ny9f3j4+OwaMQtAAAAP3RSTlMAEGCfz+//XyCQ7/////////+P/////4/f//8wMP//////oP////+Q/////2D///+f/////////////////6C6ljraAAABbklEQVR4AYWTBXIDMQxF5TCuwssbZsYy9/5nqhZqOfyGDF/PI48NjIjFE8lUKpmIpwWck8nm8oWihqiVCuVUPAPHiEq1pqGkX mvox+WGGW5zxDIUiW0U8IyC4XC9y+uM++8QXH/qCLupWHgFUw8OaNTlitdstVptOdWq/iGdLpf0+hQY8Lw2BBApFozGk+mxIidgVlYE4/GcAgteyc+gU1ME4/FkSYk8N7KCREnO1hTobSiwlUvFBCT5jncU2B8o8CAVWhJSR4JH xAElnuRiSgk8U2CN2KbACwf4CI/2XxFDRZuPSBS5RxIQb8pllRLwXuMeAwF+LFlBbc7yLOhhwCcFv jCgnAaR0wJB0CNKRdhpPSUAhl15SRghL6u2AoBM1Vd8e573gxG/7Xb74AsawZsamngFaxg9udqtJ3f/0RIOO9R6W/04Vh2P0EyqVxDDRleJaN3qUJx+3vdUuVYKPm8tnxtyOSNm79H3 nynVf7p0Qn8VRyvPAAAAAElFTkSuQmCC[/img]
    Axios
  • Why Teslas and other electric vehicles have problems in cold weather
    Jan 18, 2024 — Why are EVs affected by cold weather? First, chemical and physical reactions inside an EV's battery require more time ...
    [img alt=""]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAACAAAAAgCAAAAAB WESUoAAABIUlEQVR4AZSTLYyEMBCFnw8JqgmqCd77c+cQ60gw6 K734sz6IPDYU7j1q1biEySqClXzrvxP9sg2+4k2mX7QTmeKNMB HQoKV5FRQyNveka5vC6j/AszAncHgRdB4kJIHtBQ0Br4wxFoIx7owcAjb/5+VyTJTPbddNkEZesYbcOus7So/O3quahVgSTZA7rhQAL8kLRYhKeaYyrlTxiinYDILaMmvWMPxIN JRRrZYhJ5llEY1BY0PGParwPs0dhTMS3duQqT9OFIw+rhWISFm eAt5yIqCWhxyTTOVaTro6HtPMylJ5lAX7hQKxTQl4qpr4OLW73 OgEVedqis99mct1lS0URYrXO7zhrHQ4ZYLNO2btrcGZw+nePtw/oYr61GeuwH7VuBWBsV2CQAAAABJRU5ErkJggg==[/img]
    CBS News
Old Nov 7, 2024 | 10:56 PM
MBNUT1's Avatar
2010 E350 4Matic
Well the relative decrease in reduction in range for an EV vs an ICE in cold weather is really a testament to the vastly superior efficiency of EV's vs ICE cars. ICE cars **** away most of the climate changing fuel energy in heat that can be diverted to cabin in the winter whereas EV's have to use energy which would otherwise be used to move the car to heat the cabin.
If an EQS580 had as much energy in it as a full tank of an S580 it would have close to 2400 miles of range.
Old Nov 8, 2024 | 01:37 AM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
I guess that’s the closest I will get to an apology.
Old Nov 8, 2024 | 08:45 AM
GreasedFolgore's Avatar
2025 Maserati Grecale Folgore and 2024 Jaguar F-PACE SVR
Cold actually reduces resistance so electrons flow more easily. Check out videos of quantum locking using superconductors if you don't believe me (I recommend The Action Lab on YouBoob). It's the ions that slow down. So I wouldn't be surprised if range actually goes up in the winter when new battery technology gets released.
Old Nov 8, 2024 | 09:12 AM
MBNUT1's Avatar
2010 E350 4Matic
No apology nor will be there one forthcoming. You jumped into this thread by saying that if you were trapped on the highway in a blizzard you would more likely to freeze in an EV than an ICE car The video from the Norwegian guy makes clear that is not the case with the same percent of tank content.
But as a consolation I provided the following for you:
https://www.topgear.com/car-news/sat...etrofitted-v8s
Maybe I can also send you a subscription to Climate Deniers Weekly.
Old Nov 9, 2024 | 10:20 PM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
Earliest snow storm in Colorado in decades. Great for ski resorts. Not so much for glow bull warming.
Old Nov 9, 2024 | 11:04 PM
  #32
c4004matic's Avatar
17 E43; 21 GLS580
Yep. Just like COVID entirely made up. Oh biy these are going to be some entertaining years. The idiots think they have been vindicated.
Old Nov 10, 2024 | 12:25 PM
  #33
MBNUT1's Avatar
2010 E350 4Matic
In other news:
"In a few terrifying hours, the Mountain fire exploded into SoCal’s most destructive in years"
