EQS EQS (V297) sedan
Charge port stuck
Old Feb 11, 2025 | 08:14 PM
asdf's Avatar
Charge port stuck
My charge port couldn't open and was replaced last year.
Lately, it's been erratic, requiring several pushes to open.
Has anyone encountered this?
If this happens on a trip, what can I do? Pry it open with a screwdriver?
Old Feb 12, 2025 | 09:34 AM
teksurv's Avatar
2024 EQE 500
I've not heard of this happening. I would check the manual to see if there's a secondary release, but I doubt it. Other than that, just returning to the dealer is all I cold think to do.
Old Feb 12, 2025 | 10:23 AM
Diesel Benz's Avatar
This is a very common problem on different MB models (including plug-in hybrids) here in Europe, specifically during the winter if the car is often charged under an open sky. Odd that the fuel tank flap works well. Perhaps because it is not open for a long time outside.
Some owners change the solenoid almost every year. Some get frustrated and remove the solenoid, replace it with a bit of velcro tape.
Old Feb 12, 2025 | 10:39 AM
FirstEV's Avatar
2022 EQS 580 Sedan
To manually release the locking latch of the charge port: remove a small, insulated panel inside the rear trunk - on the right side - and pull a small cable found behind the opening. Hope this works for you.
Old Feb 13, 2025 | 07:20 AM
nath_h's Avatar
2008 CL550, 2022 EQB 300, 2023 EQS 450 4Matic
This happens occasionally on my EQB. A lock/unlock cycle works for me every time.
Old Feb 13, 2025 | 08:20 PM
LAZARU5's Avatar
2025 E53 Hybrid
My EQS SUV port flap was frozen shut recently. I tucked a length of dental floss around the non-hinge edge of the cover using a ball point pen cap. I had my wife press the dashboard "open" button while I tugged the flap open.
Old Feb 17, 2025 | 10:46 AM
c4004matic's Avatar
17 E43; 21 GLS580
WD40......
Old Feb 8, 2026 | 04:53 PM
jmn's Avatar
jmn
credit card
Slide in a credit card on the left side of the port. pull away from the port (so it pushes to the middle). push the lid to activate the mechanisms. works very fine. need to do it all the time during winter. Actually crazy.
