EQS EQS (V297) sedan
What is the value of sign in personalization?
Old May 18, 2025 | 12:09 PM
EQSguy's Avatar
I usually sign in to my 2022 EQS sedan when I drive. But it does apparently nothing. Does not adjust the seat and mirrors to my settings. Does not adjust the climate control or the media interface. Does not adjust regen setting. What benefit is this feature?
Old May 18, 2025 | 12:41 PM
ScottC2's Avatar
2023 EQE SUV 500 4Matic
Did you ever go through the profile setup routine? This is where it memorizes seat and mirror positions, audio preferences, etc.
Old May 18, 2025 | 03:52 PM
W205C43PFL's Avatar
Did it default to guest profile or did you save your settings to guest profile and not your own profile?
Old May 18, 2025 | 04:15 PM
EQSguy's Avatar
I set up my personal profile; it calls me by name. I have saved, for example, the seat position using the buttons on the door. Do I need to save it in a second profile?
Old May 18, 2025 | 05:14 PM
W205C43PFL's Avatar
Try setting another profile and play around with it, maybe it glitched out.
Old May 19, 2025 | 08:59 AM
Diesel Benz's Avatar
These profiles seem to have a mind of their own, I have not learned to master them properly. But if your seats were not adjusted to your settings, someone must have been driving the car previously. Perhaps this driver used your profile and adjusted seats to his/her linking?
Old May 19, 2025 | 02:38 PM
W205C43PFL's Avatar
Worth checking it out or perhaps create a new profile to check if the settings can be saved over there.
Old May 21, 2025 | 04:42 PM
runbuh's Avatar
2023 X296 EQS 580 SUV / 2018 991.2 Cabriolet
I am tall, and my wife is not. We both drive our EQS a fair amount. What's the point of having the profile settings for your seats if the seats don't move BEFORE you get into the car? Every Porsche and BMW I've owned for the last decade (or more) has tied the profile to the KEY. You use the key to remotely unlock the door, and the seat, steering wheel, and mirrors all adjust as you walk towards the car. As it stands, now, I have to unlock the car and use a seat preset (and wait) and then call up my profile for the car once I can physically get into the darn seat. From what I've read, even the EQE has the ability to tie ("secure") the profile to the key. Why doesn't the EQS?
/rant
//first world problems
///need three slashies
Old May 21, 2025 | 04:59 PM
W205C43PFL's Avatar
/rant
I guess the only way is (I think it was mentioned) is memorize the exit position as I guess "3" then restore to driver position "1".
Old May 21, 2025 | 05:05 PM
runbuh's Avatar
That's what we do. Wife is "1" and I am "2", like so many things in life.
I just want this SmartKey Recognition option added to the EQS:
Old May 21, 2025 | 05:21 PM
W205C43PFL's Avatar
What EQ model is that?
Old May 21, 2025 | 05:23 PM
runbuh's Avatar
EQE of unknown MY:
https://mbworld.org/forums/eqe-v295-...ml#post8977635
Old May 21, 2025 | 05:25 PM
W205C43PFL's Avatar
Thanks for helping me find the source, looks like the car might be an European spec.
Old May 21, 2025 | 05:42 PM
runbuh's Avatar
Canadian - scroll down a couple of posts from that link.
Old May 21, 2025 | 08:05 PM
W205C43PFL's Avatar
Oh hmmm
Old May 21, 2025 | 08:28 PM
W205C43PFL's Avatar
Can you compare the two software versions? Yours and theirs?
Old May 21, 2025 | 11:03 PM
runbuh's Avatar
Mine is E329, which is older, as I understand it. E445 and higher seems to be where the feature starts showing up on EQE’s, based on what I read in the EQE part of this forum. I need to make up some crap about something wrong with my car and see if I can get the software upgraded to E505 (again, based solely on my reading, not on any actual facts). Perhaps with a newer version I can see if the feature shows up.
Old May 22, 2025 | 10:10 AM
W205C43PFL's Avatar
That is not MBUX 2.6.1 if I recalled that folks are getting lately. I wonder if you can bring the vehicle in and force them to update to the latest version that way.
Old May 22, 2025 | 10:12 AM
W205C43PFL's Avatar
Was able to confirm MBUX 2.6.1 is E505 https://cimg7.ibsrv.net/gimg/www.mbw...b1010dcfc2.jpg
https://mbworld.org/forums/eqs/90729...x-2-6-1-a.html
Old May 22, 2025 | 10:16 AM
W205C43PFL's Avatar
Try asking them if they got the smartkey feature.
Old May 23, 2025 | 02:08 PM
W205C43PFL's Avatar
It seems like they are starting to come out with it in the usa but only on the W223 S-Class starting (2025?) model year. https://mbworld.org/forums/s-class-w...ml#post9165316
Old May 24, 2025 | 07:37 PM
J_Boxer's Avatar
24 EQS 580 4matic sedan Pinnacle trim w/Exec. rear seating pkg.
The 2023 EQS 450’s fingerprint scanner was a lesson in forced tolerance. While it would, eventually, find the correct profile, its performance was unforgivably temperamental—a flawed system demanding user patience for a basic function.
The 2024 EQS 580 doesn't just improve upon this; it renders the entire clumsy process obsolete. Facial recognition provides instantaneous, seamless authentication. This isn't an "improvement"; it is the correct solution from the start.
The proof is not some trivial icon on a screen; it is the immediate transformation of the cabin's atmosphere. My profile engages, bathing the interior in vibrant blue light at maximum intensity and—most importantly—silencing the contrived powertrain acoustics. This stands in stark opposition to the other driver, who prefers muted lighting and the full "Enterprise woosh" enabled.
There is no ambiguity. The car simply knows. Instantly.
Furthermore, the dynamic cruise control has been meaningfully refined. The interval before the system demands you touch the steering wheel has nearly doubled. This is a significant, welcome change that reduces digital nagging and better trusts the driver's attention.
Old May 25, 2025 | 10:45 AM
W205C43PFL's Avatar
Strange, I don't have problems with ours, did you try training a different fingerprint?
