3.47 Rear Differential for C/SLK 02-05
2005 C230k 3.47 rear differential w/ 21,000 miles on it
to swap with my rear end outta my '06 c350. Just found out that in 06 they changed the housing so it won't fit.
This will fit some 01-05 C or CLK. If you're looking to upgrade to a lower gear ratio, repair, or exchange your high mileage rear end, here ya go.
I bought it from a Benz-BMW grave yard.
EDIT: Also can be purchased for the ring gear and pinion to use for rebuilding your current pumpking if your application cannot allow for a swap. non-amg cars only as they have a larger ring gear/pinion.
$300 shipped
EDIT: cant guarantee itll fit SLK. Swap into a w203 other than a c230k may require swapping some of your current hardware over to this pumpkin.
Swap into an automatic tranny car will require TCU programming if going to lower ratio. Manual cars have nothing to worry about.
This will fit 02-05 C or SLK. If you're looking to upgrade to a lower gear ratio, repair, or exchange your high mileage rear end, here ya go.
$300 shipped
BTW, the diffs in those pictures are from a W211/W219, not a W203. Perhaps they just used generic pictures.
The only cars your diff will fit are the CLK240, C230 Kompressor, C240 and C240 4Matic. It will NOT fit the SLK. Let me rephrase that, it will fit the SLK200 but that car never made it stateside.
Thank you for the headsup! If I could change the title I would!
I've tried using EPC to figure out a commonality behind this differential, and wasn't having much luck. The parts foreman at my local MB dealer couldn't help much either.
So, those cars you listed are the only direct swaps for this diff? Can it be swapped into any other with limited modification without rebuilding the pumpkin? Like changing the prop flange or any of the external seals?
Let me ask you this, do you know what differential(s) could swap over to mine c350?
The part# for my diff goes something like 203 350.... (shares these first 6 with the c240... so until I read your post, thought maybe a c240 would swap over to mine) and I have the 110mm prop flange, unlike the 100mm of the 05 c230k diff I purchased.
Now includes 2 quarts MB diff fluid @ $375 shipped
This is a poorly planned mod that didn't turn out. Caveat emptor, this diff can cause more problems than anything. Can't imagine why anyone would want to do this in a sufficiently geared car such as the C-class.
e1000 - you point out why not to put this in an auto, when I advertise it for a manual.
you relay your opinion in the worthfulness. others have apparently, myself included, enjoy what a lower gear ratio has done for their particular application. Just because you don't believe that the C class can enjoy any benefit from a lower gear ratio doesn't mean that someone else might think differently. please let any potential buyer come to this conclusion themselves, you continue to antagonize me and this has officially gone too far.
I never said shorter gears were a bad thing, just think they're useless on a C-class. You keep saying I'm the one with no real facts, but others have even stated with video proof that most likely, shorter gears will do nothing for the overall performance of this car.
Again, CAVEAT EMPTOR. There's nothing wrong with a rear-end swap, but just want to make sure the next buyer is fully aware of what the result will be, and what potential issues they might have.
Unless I've broken the TOS, I'm free to post wherever I like at MBW, officially.
In your case, you're seeing the benefit because with the 3.07, you are just getting started with 4th gear before you finish the quarter mile. You're trapping higher with the 3.27 because you build momentum in 4th with that FD. What were your ET's with each set of gears and nothing else changed? With modern gear boxes, swapping for shorter gears means that the car will be quicker during certain speed ranges and slower in others. It's a give and take. The overall performance of the car will change very little if any. Not sure if you saw this video posted, FF to the 40s mark.
http://www.youtube.com/watch?v=e32gozeyXLo
I'll have a C with 3.46 gears I'll be playing with this spring so it will be interesting to see what I can get out of that.
I've *tentatively* sold the differential and I will be working closely with the buyer to make sure we get accurate results.
RC- do you know of any 210mm ring gear/pinion sets with ratio other than the 2.83 (my c350 and many others) and 3.06 (c32, c55) available thru MB? Expense will keep me from doing this immediately, but will be on the hunt for the 3.06 gearset and quaife lsd in the meantime.
