Advice on a 2003 G
Should I be worried that all these were done? What does it mean? Do you think all the bugs are out ???. Is this typical for a a G500?
transfer case jolts
propeller shaft transfer case
k/z control unit
converter lockup clutch jolts
gasket cylinder head cover
housing transfer case leaking
hinged rod link torsion bar
homokinetic propeller shaft br all at 37000 miles
propeller shaft transfer case at 34000 miles
blower regulator not operating
blower regulator contact fault at 30460 miles
steering shaft power/hydraulic at 29951 miles
bass not operating (stereo) at 27355 mi
heating pad front seat
electric window lifter not operating
jacket tube module not operating 25000 miles
door control unit right front
switch warning flasher system
sunroof wind deflector
shielding plate exaust system 23000 miles
Servo motor transfer case 19000 miles
TOWED TO DEALER for malfunction of transfer case servo motor at 12000 miles
Should I avoid a unit that has had all these problems or is this typical.
The warranty is up.
I appreciate any and all advice.
