Engine Noise 2002 G500
Does anyone have any idea what would cause a really loud engine noise to start when I go over 45 MPH and the temperature is around 70 degrees or below?
It does not happen during the hot summer months only when the temperature drops and I go over 45MPH?
Thank you
Thank you
"really loud engine noise" needs a better description.
If it's hot outside like it is today, the fan runs on my 2002 G500...but it doesn't go on-and-off. It shouldn't run at highway speeds, only when there isn't enough airflow over the radiator. You should get it checked by the dealer if it happens all the time. You could hit the little wrench button in the arm rest and see what the MB technicians say. I've done that from time to time and they are very helpful.
Does it make the same noise when you are parked and rev the engine to the same rpms?
Drive the car until you have the sound then find a safe place to pull over or return to your driveway and perform the test above. An assistant would help pinpoint the noise.
Good advice from the OP above but there could other possibilities, I reckon.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
I noticed last year on the Moab trip that the G500s had loud fans. They ran a fair amount even though the ambient temps were pretty low. That is slow going though and the engine has obvious cooling needs. the fan in my '90 300GE was really loud too.
Thanks for responding. I really need to bring it to the dealer and take a look. The voice can come and go and usually improves as the temperature gets warmed and the more I drive it during the day.
Thank you
Thank you
