G55 Right Rear Window will not roll up
I have a 2011G 350 with both rear windows not working. The past owner could not give me a ton of details he just said they did not work.
I took a look at the plug in the window and there seems to be electricity when you touch the yellow marked plugs with the red marked plugs. The unmarked wire does not give any electricity when the button is pressed, which is a difference from the front working window.
Front windows work fine. Looked at the fuses and all seems ok. I checked the wires in the door and they don’t seem to be cut.
So I was thinking it was the motor. I bought a new regulator and plugged it in and it also does not fix it.
I ordered a new front switch but it is 2 more weeks for it to arrive.
I took the back switch off and checked the circuit is open and closed when the button is pressed. So that seems ok.
Does anybody have a wiring diagram or ideas on what to check? Is there a way to check if the switch is working if resistance is not correct. Could it be the box for the rear windows?
2011 window plug for class G
