ESP, BAS, ABS, Brake Booster, Brake wear. No speedometer! Please help!
Old May 10, 2015 | 11:12 AM
JimGarsen's Avatar
MB G55 AMG
Hello!
I’ve been browsing this forum for answers to my problem but I'm having a hard time to do so.
I own a Mercedes Benz G55 AMG 2006
Problem: Following warning lights has come on ESP, BAS, ABS, Electric Brake Booster, Brake wear. All saying 'visit workshop!, display faulty!.
Before it appeared:
No apparent problem with the car, drove a couple of miles in winter conditions, stood idle with engine on in the cold, sub-zero (Celsius), with heating on inside for the dog i the trunk.
After an hour or so, car still running, all warning lights were illuminated. I shut it off, disconnected the battery restarted, everything was still there. When I drove home, I also apparently see that the speedometer is out of business stating 0km/h.
Then the car stays put for a couple of days, the snow melts and warm winds. I start the car, all warning light has gone away. Even the speedometer is up and running.
Then a couple of starts later, all still gone except, 'Electric stabil. Prog. Visit Workshop! ESP.'
A week or two later all of the same messages popped up again. Wet weather, and ever now when all has dried up thing are the same, no speedometer and a bunch of warning messages, ESP, BAS, ABS, Electric Brake Booster, Brake wear. However, the car runs fine, all the fuses are ok, the brakes are ok, the lights work fine, however a diagnostic computer doesn't get connection with the ESP/ABS control unit.
Since the problem came, disappeared and came back, I would like to think that there is some problem with the wiring or connections to the ESP, ABS unit.
The only info I have found was:
"Mercedes-Benz G55 AMG Connector/wires for brake pressure switch may be damaged due to rattling/chafing
Due to the location of the ABS hydraulic unit on the inner fender, the connector (or wires) for the brake pressure switch can be damaged when the connector rattles or chafes against the inner fender. This problem will illuminate the ESP warning light"
Now if this is it I don't know? Do you have any ideas of what the problem might be? The control unit is expensive and I don't trust the repair shop (neither would you) want to keep the cost down.
Could it be the ACCELERATOR SENSOR?
Sorry for the bad writing, obviously it's not my native language.
Any response is much appreciated!
Attached Thumbnails ESP, BAS, ABS, Brake Booster, Brake wear. No speedometer! Please help!-11261924_10154112803142195_7820818941033649486_n.jpg   ESP, BAS, ABS, Brake Booster, Brake wear. No speedometer! Please help!-11169155_10154112803152195_7690149935741362430_n.jpg   ESP, BAS, ABS, Brake Booster, Brake wear. No speedometer! Please help!-10390538_10154112803162195_8466509921343813217_n.jpg   ESP, BAS, ABS, Brake Booster, Brake wear. No speedometer! Please help!-11244943_10154112803187195_3228992062638993905_o.jpg   ESP, BAS, ABS, Brake Booster, Brake wear. No speedometer! Please help!-11039819_10154112803177195_9204150132292397205_o.jpg
ESP, BAS, ABS, Brake Booster, Brake wear. No speedometer! Please help!-11245536_10154112803357195_2918827306354884475_n.jpg
Old Jun 25, 2015 | 02:41 PM
kaveh's Avatar
There is a 90% chance that there's massive corrosion on the connectors of the ESP + BAS module on the driver side foot module.
To diagnose it, remove the front passenger carpet, on the upper portion of the foot panel besides the air duct that goes to the rear passenger section, there's a module held by four size 10 nuts. Remove the bolts and loosen the module, be really careful when removing the module as the pins might be corroded and they might snap due to lessened strength. you'll see corrosion on the pins and the connector itself.
let us know if this leads to the culprit.
Old Sep 1, 2023 | 06:30 PM
ntropy's Avatar
2005 G55
Were you able to find a solution?
To anybody else is experiencing this issue, check the ABS fuse located under the glove box.
Old Dec 24, 2024 | 07:56 AM
BullittAZK's Avatar
G 55 AMG
Same problem here right now. Can U folks give me a correct location of a ABS fuse for G55 Amg 2011?
Old Dec 24, 2024 | 11:30 PM
djantlive's Avatar
I’d check the speed sensor. They go bad and disrupts all the electronic nanny
Old Dec 25, 2024 | 02:48 AM
BullittAZK's Avatar
G 55 AMG
Guessing- located somewhere in the tranny?
Old Dec 25, 2024 | 05:26 AM
djantlive's Avatar
Speed sensor is at each wheel mounted usually to the wheel hub.
