Radiator fan running too often
Old Mar 28, 2016 | 11:23 PM
goinsurfin's Avatar
2004 G500
I've been reading about this issue on many other MB cars, but for the Gwagon, nothing. The fan does run quite often. Granted, it is 90 degrees here in FL so is this normal or is the radiator fan to sensitive, or are there fuses, etc causing this to run longer than normal..?
Any G owners have this experience that can chime in?
Old Mar 29, 2016 | 02:22 PM
goinsurfin's Avatar
2004 G500
Originally Posted by Plutoe
The fan is supposed to run when the coolant temp and or the AC refrig temp exceeds a certain levels---sounds like its doing it's job--that all assumes you have the correct coolant and ratio------and your coolant\refrig temp sensors are not faulty!!
Oh really, ok then great! However, I will check the coolant and ratio + sensors to also confirm they are set...Thanks!
Old Apr 8, 2016 | 04:45 PM
kotton's Avatar
2011 E550 , 2006 G500
This is common with the G. Honestly its just how the car was setup to make sure it stays cool in hot desert climates. Im in SoCal where the weather is about the same temp as yours, and my aux fan runs constantly.
You have to remember this vehicle was originally designed for the sheiks in the middle east, and they are still really popular over there.
Old Apr 15, 2016 | 03:38 AM
victordakhteh's Avatar
2003 G55 AMG
I am also on board with everyones answers, frequent running of the aux fan is normal, especially when using the A/C, while go off and on by the minute depending on the overall temperate and A/C usage. When it stops running is when you should really worry.
Old Apr 16, 2016 | 11:37 PM
goinsurfin's Avatar
2004 G500
I found a excellent indy MB mechanic that knows these trucks well. He too, says that the fan will run esp when the AC is below 72 degrees and outside temp is 80+. Indeed, these trucks are designed to withstand extreme temps.
It's comical contrast that when at a stop light, the car next to me turns off and goes quiet bc it has the start/stop feature... but on my side, my truck gets louder b/c the fan turns... Also, each time I go through the Starbucks drive thru, I have to turn the truck off...then cannot hear me..I love it!
Old Apr 18, 2016 | 12:03 AM
kotton's Avatar
This last trip we took to Lake Havasu, when we were leaving I had the G running so the AC was cooling it down before we left ( it was 96f outside). It pretty much resulted in a lot of "What!?" when we were telling the rest of the fam bye outside.
