ECU Flash for more HP
Old Sep 19, 2017 | 08:01 PM
just1time's Avatar
s550
Considering getting a W463 soon. More than likely will be picking up a g550.
was looking into getting more HP and found this online.
https://www.gwagenparts.com/product/...0-v8-bi-turbo/
$1500 for about 140 gain in HP and 200lb-ft increase in torque. Sounds like its worth it to me.
Are these tunes realistic? safe? Anyone have experience tuning their g550 for more HP?
Old Sep 19, 2017 | 09:59 PM
Munich77's Avatar
Mine: 2014 E550 4matic; Hers: 2016 CLS 400 4matic
Tuning the twin turbo V8 is proven.. I would look at Renntech too!
Old Sep 19, 2017 | 10:38 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
We can help at eurocharged too for a lot less $!
let me know if you are interested or drop us a line!
Old Sep 20, 2017 | 07:03 AM
invictusmaneo's Avatar
Lifted G500, GT-S, track Cooper S
I got a eurocharged tune on my G500, and while obviously not going to have the impacts it would on a turbo motor, it runs better, sounds better, pulls more aggressively in first and second due to the mapping, and has been getting about 1-2 mpg better since. I think I only gained 20 hp and 20 ft lbs but it was worth it, and the flexibility of their tool is very nice, particularly considering the price.
Old Sep 20, 2017 | 06:19 PM
just1time's Avatar
s550
hey
I like that you are local.
i was on your website but couldn't really find anything specific for a 2013 g550. Can you tell me the exact gains in HP and torque you guys can achieve for a 2013 g550.
thanks
Old Sep 21, 2017 | 08:42 AM
loungn14's Avatar
SPONSOR
thanks
31hp and 37 tq
Old Sep 28, 2017 | 07:51 PM
GFiveFifty's Avatar
2010 G550, 2010 Bentley Continental GTC Speed & 2019 S560; 2026 G63 on the way
I had Kleeman flash my 2010 G550 (naturally aspirated V8) for under $1000 and there are pros and cons to it.
Granted, all of this may be different for the newer bi-turbos but I find that, after the flash, the transmission stays in gear much longer while full throttle (into the redline) and that has taken some getting used to. Specifically, at times, I have to shift manually or with the accelerator by letting off a little bit so not to run the RPMs too high.
Other than that, my G is noticeably quicker and sounds phenomenal. The numbers likely went from around 380hp & 380lb-ft to above 400 for both.
