DRL AND TURN SIGNAL LIGHT UPGRADE QUESTION
Old Feb 3, 2018 | 12:33 AM
Jpballer87's Avatar
S500
Hello all,
I have a 2002 G500. I purchased DRLs and updated side mirrors. My current side mirrors only have one plug for mirror function. New headlights have 2 wire, one is the same as my G500 oem mirror. The other I assume is for the turn signal. How do I wire the turn signal light even though I don't have it.
Also what fuse should I tap to power my DRLs? I saw something about the aux fan pump but I would like them to come up when I unlock the G...
Any suggestions would really help!
Old Feb 5, 2018 | 08:20 PM
Floobydust's Avatar
2018 GLE350, 2014 G550, 2000 SL500, 1980 TR8, 1995 E320 Cabriolet
You're not going to find an easy point to "tap" that will illuminate your DRLs when you unlock your G - that would require some external logic to accomplish, although, if you do what I did ( http://www.benzworld.org/forums/g-cl...l-install.html ), you will get close.
Using that circuit, the DRLs will:
- Come on when the key is turned to the on position.
- Come on when the parking lights are on
- Come on when the truck is unlocked at night
- Dim when the headlights are turned on
- Turn off when the key is turned off.
- Stay on when the delayed lights exit function is active
If your DRLs do not have a "dimmer" input, just don't include that part of my circuit - you will just lose dim when the headlights are turned on feature.
Old May 26, 2018 | 04:14 PM
180sx's Avatar
g55,clk63
thank you very much for your post very helpful. would really appreciate little list of the parts needed ")
