2016 G63 alignment
Old Sep 14, 2018 | 06:14 PM
hhuytho's Avatar
2016 G63
2016 G63 alignment
I just bought a 2017 CPO G63. The steering wheel was not aligned (rotated to the right) and also the car tends to move to the right while driving. The wheels were also out of balance, which is another problem as the dealership mounted 4 new tires for CPO.
I brought it to a well-known local shop which is specialized in racing. They redid the balancing which fixed the vibration on the steering wheel. They tried to do the alignment as well but it turned out the the rear axle was out of alignment. In order to fix this, they recommended that the trailing arms needed to be shimmed to create proper alignment. Does any of you guys experience the same problem on the G?
I have refused the repair and made an appointment with the dealership to try to fix this under warranty. Do you this that it should be covered under warranty as I think this is a defect?
Thanks.
Old Jan 4, 2020 | 12:15 PM
Bob Weston's Avatar
w463 300gel
Hi Hhuytho,
i have the same issue with my LWB W463 300GE. However my car is RHDrive and it pulls left. The readings are similar on the alignment -0.10 on rear left and 0.15 on rear right.
my gut says I should shim the trailing arm to the rear right ?
Did you manage to get this fixed by shimming? Or another solution?
oI thanks ?
Bob
Old Jan 4, 2020 | 02:58 PM
hhuytho's Avatar
2016 G63
Originally Posted by Bob Weston
Hi Hhuytho,
oI thanks ?
Bob
Hi Bob,
Yes, I brought it to another shop with the shim bought from a Mercedes dealership. They did the alignment with the shim and it seems to fix the issue. I had to tell the shop about it as they were not aware of this fix though.
Old Jan 5, 2020 | 07:47 PM
Bob Weston's Avatar
w463 300gel
Originally Posted by hhuytho
Hi Bob,
Hi, thanks for your reply and it must be a sign of how little is known of this fix i.e. my follow up to the thread was a year later. I’ve had my tracking done 4 times in 4 years by three different shops and they have always said it’s because of big tyres and the camber in the road. ( RHD here left camber ) You mentioned that the dealer supplied the shim, was this just a thick washer or a couple of washers?
can you remember what side they put it on.
i had a hunch that this was the only way to adjust the axle position and then I found your thread mentioning shims. Thank you for taking the trouble to list the problem and taking the time to come back to me. Regards Bob.
Old Jan 6, 2020 | 03:17 PM
hhuytho's Avatar
2016 G63
I got this document from another forums (pointedthree.com). It has the part number and instructions for installing the shim.
File Type: pdf
Old Jan 6, 2020 | 04:14 PM
Bob Weston's Avatar
w463 300gel
Thanks again, I will order the shims and get this done.
cheers Bob
