changing front SAM: Do I need help?
Old Dec 19, 2018 | 02:21 AM
CG 270cdi's Avatar
G 270 cdi
My front sam got really wet and the dealer says it needs replacement.
If I were to buy one and replace it myself, will there be programming or another reason I would need to use the Dealer for?
2002 G270 (same SAM as G500)
Has anyone done this?
Old Dec 19, 2018 | 04:05 PM
Gregoogle's Avatar
2014 G63, 2008 G500, 2019 RS3
It’s easy to get to. Basically remove the kick panel above the passenger footwell. Shouldn’t take more than an hour or two start to finish. There are many plugs so make sure you record which goes where (usually they’re clearly marked). As far as reprogramming you might need a STAR system to clear any error codes. Good luck!
Old Nov 16, 2019 | 11:37 AM
FMBUSH's Avatar
2007 ML 320 CDI
Can they reprogram a used front SAM?
Old May 4, 2020 | 10:49 PM
acmw's Avatar
m6
interesting
Old May 16, 2020 | 11:46 PM
Chris Sirch's Avatar
G500
/Bump did you resolve this?
