Oil wetness/seepage near differential area
Old Dec 24, 2018 | 03:44 PM
mrtonyn's Avatar
1999 E320, 2008 S550, 2016 G63 AMG
2018 G63 with 12k miles.
Is it normal to see oil wetness/seepage on bottom of the front differential housing near the plug?
I have also seen some oil wetness on the part that looks similar to a shock absorber installed horizontally near the front differential as well. See pictures:
What is your opinion, is it normal or something is not tight? It has not leak on the garage floor yet and the previous owner had the steering shaft replaced/repaired at 3,500 miles is what is on the Carfax history.
Thanks.
Old Dec 27, 2018 | 10:45 AM
JesseRohr's Avatar
G63 AMG, Lamborghini LP580-2
Check to see if that plug is tight on the bottom.
Old Dec 27, 2018 | 12:16 PM
mrtonyn's Avatar
I was going to tightened it but don’t want to over torqued it since I don’t have the correct socket/torque wrench.
Asked my mechanic about it and he says the factory spray some protective layer around that area to further water/rust proof it.
