Shock Install
A few others have tried the shocks on the full soft setting and found there was too much sway during acceleration and stopping. Recommended setting for the 'softest' ride is for 2-3 clicks in the front and rear. I plan to set mine at 4 and 4 to start with when I do my install next week.
Anyone ever run into this? I feel like a super newb now and just want to make sure I'm not missing anything.. Any input would be great. I'm not ready to grind open the shock and rip it out as I don't have the Fox shocks yet (probably get them for myself for christmas) Thanks!
Since you have not yet purchased your replacement shocks, it may make sense to just do the spring spacers with the shock install at the same time as you won't have to worry about cutting the shock nut off if necessary. You could go to a shop with a commercial grade air tool setup with higher breakaway torques and ask them to loosen the nuts for you first, but there is always a risk of the shock threaded shaft breaking without having replacements on hand. I would also recommend installing longer diff/brake lines at the same time since you're already in there, and by removing the diff/brake lines, you can drop the axle all the way down and may not need to use spring compressors.
