Good all Season tire for G63
I have a 2019 G63 with 21" wheels wearing the stock Pirelli Scorpion Zero (285/45/21). I took it off-roading in SoCal and it proved quite capable. However, you can see from the below photos that at maximum compression and articulation on the rear axle, the tires nearly touch the inner liner of the fenders. The K02s running at their smallest size on 20" (the minimum wheel diameter capable of fitting the large brakes on the G63) would be 275/55/20. These are definitely going to rub and possibly cause problems under maximum articulation. They will likely work fine when not under max articulation - but it seems the capability of the K02s would be limited if the vehicle isn't allowed to traverse varied terrain. Thus, it seems the Pirelli Scorpion ATRs are the only viable option on the '19 and up G63 without any lift if one plans to run the G through its paces on terrain like the below.
Full suspension articulation.
Rear axle compression under load
And yes, I had all three differentials locked in order to traverse this section. I did make an attempt with just the center and it did move about with some protest. Locking the rear diff was good enough to get through the section, but it was without any grade.
With all three diffs locked, the G63 easily walked up the below section without drama. Interestingly, I watched all sorts of Tacoma TRD Off-Road variants slipping and sliding up this hill. I got a lot of inquisitive looks and at least one "thumbs up" taking the $200k truck with 21" stock wheels up it with ease.
I attempted a rock crawl section, but I found the 9.5" of ground clearance to be not quite enough. I slid off a rock and the slammed the front brush guard into it. Even though just two bolts secure it to the chassis, it was enough to basically stop the impact from ripping off the bumper, though I walked away with some pretty big gashes in both the bumper and brush guard. I did make it through that rock crawl section though, and again, watched all sorts of other vehicles slipping and sliding through it.
One thing to note - the side pipes on the G63, while sharp looking, are not ideal for off-roading. I found that they "got in the way" in the sections posted here. I scratched the underside at least a couple of times when getting one wheel in the air.
Uphill frame twister, required three diffs locked
@ArtsE500 Awesome to see you put the new truck to intended use! I really like the new generation G and hope to get one in a few years. It looks much more 'mature' and modern on the inside, ha.
The wimpy passenger tires may be ok for sand, but the moment you get to rocky or gravelly terrain, you will get flats/torn sidewalls real fast because of lack of beefy sidewalls. It's also why running 21" wheels is not an option for any sort of real off-roading, and you have to downsize to 19 or 20 at a minimum and get some rubber around them.
Also correct on the silly side tips, cutting them off was one of the first things I did! Easy to get the side tips caught on rocks and push the exhaust up into engine bay or into back tires - I have seen videos of both and its not pretty.
I am also looking to order a roof rack - again, would need to be off any time I'm in city mode (most of the time) to fit under structures. There's at least a couple that are now off limits. There's one that's just a paltry 6' of ground clearance, that my Cayenne had no trouble fitting in, but is a no go with the G.
The most recent mod was a full body PPF with Ceramic Pro Kavaca Matte. Need to protect the paint from trail debris, branches, etc. Still too new to scuff up and turn into a dedicated off-roader. I like the "Magno" look produced by the matte PPF. I'd also like to upsize the wheels to 22" OEMs.
@xxaarraa
Yikes! I don't think I have the stomach, yet, to take a sawzall and slice off the tips.
