Auxiliary Headlight Mounts
Old Nov 17, 2019 | 06:32 PM
nn7man's Avatar
MY23 C63 S Final Edition
I'm looking at adding a pair of Hella Rallye Compact 4000 LEDs to my 2019 G. They should be mounted at bumper level. Anyone have any pointers towards suitable brackets and how best to fix?
Old Nov 20, 2019 | 07:22 AM
Texas E63's Avatar
Built 2008 G55 & one big 80 Series LandCruiser !
I'm having my shop weld a stainless steel tab to the stainless grill guard and then having it powdercoated black to mount a set of Baja Design Lp6's...... highly suggest them over the Hellas if you're looking for amazing light output in a compact package...... I run them on my landcruiser and they are roughly 20k Lumens and throw a nice 5k light a full 3/4 of a mile with a nice spread....
on the LC'er....
Old Nov 20, 2019 | 07:27 AM
Texas E63's Avatar
Old Nov 20, 2019 | 08:01 AM
Texas E63's Avatar
another option may be to use BD's clamp mounts ..... I wanted a more secure setup and was planning to powder coat the bar anyhow...
https://www.bajadesigns.com/products...ng-Systems.asp
Old Nov 22, 2019 | 09:00 PM
oliver_nyc's Avatar
G63
i have hella 4000s... i just attached them with these brackets from amazon:
Amazon Amazon
holding up fine.
Old Nov 23, 2019 | 05:00 AM
Texas E63's Avatar
interesting - just ordered a set to try before going the welded bracket route...... great looking G !
Old Nov 23, 2019 | 05:01 AM
Texas E63's Avatar
those are alot cheaper than the BD setup - and moreso yet then welding....
Old Nov 23, 2019 | 08:16 AM
nn7man's Avatar
Thanks for all the replies guys. The main problem I have is that EU cars don't have the brush guard (they're illegal here due to pedestrian safety regs) so welding brackets on or circular clamps don't work. I probably need to remove the front bumper and see if there is something solid to bolt onto behind it.
I haven't purchased any lights yet but was looking at the Hellas as they're circular and look OEM alongside the headlights. I already have the Brabus LED roof bars do don't need the huge output but will take look at the BD's.
Old Jan 11, 2020 | 11:21 PM
JAGGED155's Avatar
2021 G63
Originally Posted by oliver_nyc
i have hella 4000s... i just attached them with these brackets from amazon: https://www.amazon.com/Nilight-90020..._dp&th=1&psc=1
holding up fine.
Could you share photos of the switch and wiring? Also, any issues with the parking sensors, cameras, distronic, etc? Thanks
Old Jan 12, 2020 | 12:22 AM
oliver_nyc's Avatar
G63
i didn’t do the wiring myself. i had a mechanic wire it up to a switch under the dashboard (came with the hella wiring harness.) i think the trick was to wire it to the same circuit as the rear cigarette lighter so it would stay on when ignition was off as well. no issues at all with the sensors.
