Correct offset for flush wheels in a 19 G
Old Dec 11, 2019 | 08:41 AM
marcolarco52's Avatar
homeless
Looking for a set of wheels in the near future and wondering what the correct offset would be to get them flush with the fenders on my 19 g550?
I've been trying to do some digging seems like the factory wheels are 8.5 wide with a +32 offset? Can anyone confirm if that is the case?
Thank you
Old Dec 11, 2019 | 10:25 AM
johnnyderm's Avatar
Soon: 2020 G63 Currently: 2016 GLE63 SUV + 97 F250HD, Before: 2013 G550, Range Rover Sport, 1984 CJ7
Do you have the AMG package? The g550 has 52 and 32 offsets (ET32 for the AMG wheels).
From what I have seen the fender flares with the AMG package on the G550 with the ET32 wheels are not quite flush. They need about 10-15mm to be true flush. Could add spacers.
Old Dec 13, 2019 | 03:17 PM
homeless
Yes I do have the amg package with the 20" wheels. Seems as the stock offset is +32. I'm considering going with some after market 22x10.5 wheels with a low 20's offset and with 285/45/22 nitto terra grapplers so it fills out the fender wells good and should be more flush with that set up. Hopefully.
Old Dec 13, 2019 | 04:04 PM
Texas E63's Avatar
Built 2008 G55 & one big 80 Series LandCruiser !
I'm running 20x10.5 Et 20 w/ 305's...... on a G63 so not sure if the flares are the same.... it's perfect imho
Old Dec 13, 2019 | 09:41 PM
homeless
Those looks great and very flush.
Old Jan 9, 2020 | 02:03 PM
DD0220's Avatar
2020 G63
Did you add spacers?
Old Jan 10, 2020 | 09:27 AM
Texas E63's Avatar
the rims had custom offset to remove need for spacers..... saves a ton of unsprung weight, 18lbs roughly - and then the rims are 7 lbs lighter each over OEM - more then offseting the larger/wider tires extra weight.
E
