2016 G63 Lift Kit help..
Old Dec 16, 2019 | 12:41 AM
Jmoney87's Avatar
G63 AMG
2016 g63 lift kit. I am looking to do a 2 inch fox lift kit with Thor springs. The package is from Viking off road. I will add a fox stabilizer and 2 inch wheel spacers. I was wondering if I can do 35 inch tires or should I go smaller. I am completely a newbie and would appreciate any help on what set up I should go with. Thank you
Old Dec 16, 2019 | 03:28 PM
Texas E63's Avatar
Built 2008 G55 & one big 80 Series LandCruiser !
I ran 35's for a bit with just the 40mm spring spacers with 31mm spacers on stock rims and it only rubbed slightly..... 2" spacers will be close to the fender edge. you'd be far better off getting custom rims made to the correct offset and saving the weight and extra variable in bolts.... my 31mm set of 4 weighed over 18lbs...... the semi forged rims ( 20X10.5 Et25) saved another 12lbs over the stock clunkers.... here's the truck with 35's
