new owner here. couple questions too....
truck has twice thrown "overboost" code. p0234. what should i be looking at?.
catch a wiff of coolant sometimes. any weak spots? ie in my gt3s the coolant lines would pop out here n there so lines were pinned to solve issue.. is there something like that common on these?
2nd last thing. i want to take truck to zero so to speak. diff and transfer case oil recommendation?. or the castrol 75w140 that benz has? transfer case?.
and anything else i should keep a eye on or do?. cheers lee
Regarding coolant, if it were my vehicle I would stand in front of it while the engine was running and stare at it for a good long while, looking for drips and bits of steam. Do you smell coolant inside the vehicle, or outside the vehicle?
Regarding the code, best is to read codes with Xentry/DAS, the genuine M-B system. Then go from there.
From WIS BB00.40-P-0235-61A for model 463:
Hypoid oil specification MB 235.61
Aral Getriebeöl BS-LSX SAE 75W-140
Castrol Syntrax Limited Slip 75W-140
Castrol Transmax Limited Slip LL 75W-140
From WIS BB00.40-P-0239-41A for model 463 with transfer case:
Transfer case oil specification MB 239.41 transmission oil A 000 989 34 02
Search this document for model 463: https://bevo.mercedes-benz.com/bevolisten/231.1_en.html
Regarding the antifreeze smell, make sure you're not smelling the washer fluid -- some types have a sweet aroma.
