2020 G63 Manual
Old Feb 16, 2020 | 09:49 AM
CL5504Matic's Avatar
CL
2020 G63 Manual
Noticed 2 important things incorrect in the manual....
What is the quickest/easiest way activate the 360 camera ? The manual says there should be a dedicated button on the left hand side of the steering wheel - but no luck. Only a row of empty buttons.
Engine start using the Connect app should be limited to 2 times (@ 10 mins each) before needing to use the physical key. However, the actual app only allows 1 time - anyone else have that issue ?
Old Feb 16, 2020 | 04:11 PM
Surge's Avatar
W463 G550 / C190 GTC //prev: W204 C63 507 / R170
I’ve never started the engine more than once before driving, from the app. It’s not good for the engine to be idling so long, not to mention a waste of gas...why would you want to idle for more than 10 min?
Old Feb 16, 2020 | 04:13 PM
CL
Real feel yesterday was 9 degrees in NYC....Once isn’t enough to heat the interior.
Old Feb 16, 2020 | 04:19 PM
Surge's Avatar
I’m in Toronto, it heats fast! Even in -20C with wind chill, I don’t feel the need to start more than 10 min before leaving.
Not good for the engine to idle so long...
Old Feb 16, 2020 | 04:22 PM
CL
I do like it toasty...but I can’t complain considering your in Toronto. Ouch.
But the manual still says 2x for some reason, which is incorrect, per my G.
Old Feb 16, 2020 | 04:29 PM
Surge's Avatar
Right, good observation.
Now by the thermometer it’s never below about 12F in Toronto, just to be clear!
Old Feb 17, 2020 | 12:21 PM
Bkhko's Avatar
G63
my 19 stayed on for 10mins. Haven’t tried to activate it twice in a row though so don’t know about the max limit.
Old Feb 17, 2020 | 12:33 PM
mkirby's Avatar
Range Rover
The app will allow me to start the G (2019) 2 times. 10 mins each.
Old Feb 17, 2020 | 01:11 PM
CL
Damn!!!
2020 went backwards.
Do you have a 360degree camera button near the parktronic button ?
Old Feb 18, 2020 | 09:16 AM
mkirby's Avatar
Range Rover
No. just a row of empty buttons.
