2015 G550 SRS Module problem
Old May 6, 2020 | 10:17 PM
datbananaguy's Avatar
4x4²
Question 2015 G550 SRS Module problem
Good day everyone!
I have 2015 G550 that recently was transported on a platform. Truck has no visible damage anywhere, has never been in an accident, airbags have never been activated, etc. The truck had no mechanical issues before.
After transporting I got an SRS light and when scanned the error code is "B009996 - The rolloversensor has a malfunction. There is an internal component fault." The computer won't let me erase the code since it is active.
I believe that when the truck was loaded on the platform the inclination triggered rollover sensor. As far as I was able to investigate, this sensor is inside of the SRS module. I talked to the dealership but they just say that the SRS module is bad and I have to change it.
Has anybody encountered similar situation before? I took the car to local shop that specializes on MBs and they tried to reset and reprogram the SRS module (same what is usually done after accident when airbags are deployed), but this did not work.
Is there anything else I could check/do before buying and installing a new module? If not, where may I buy one?
Thank you for help!
