G550 4x4 Squared ..... on beach
I am new to my G63 so not much experience with what diff settings are to recommend. But turn the diff's off before you get stuck. Momentum while driving is the key and never stop/break in an uphill
as for letting tire pressure out, is that necessary even for the much larger and wider tires on the squared?
As for the psi, yes. It makes a huge difference and enhances traction, particularly on sand. You will want to do this.
Here is the link - https://mbworld.org/forums/g-class-w...questions.html
It is TRACTION CONTROL that you want to turn OFF; diffs are helpful in the sand. You want the wheels free spinning and not being bogged down by electronics.
To do this is the G, just place in Low range drive and select the center differential (labeled “1” of the 3 diffs). This will disengage traction control and AWD and place the G in 4 wheel drive. You want 4 wheel drive in the sand.
The 2020 G has “desert mode”, even the G550. I imagine it just does what I stated above and maybe let the engine rev a higher and/or allows 4 wheel drive/center locked diff in high range drive. Not sure.
https://drive.google.com/file/d/1uQE...X02n7AB6N/view
Installing a lift on my G55 this weekend, hoping to find somewhere to stretch it out once I'm done Sunday.
