Remove rubber stripping on windscreen?
Old Jun 12, 2020 | 11:41 AM
JD101b's Avatar
2015 SL550, 2017 GLS 550, 2010 G550, 1995 E320 Cabriolet
I've posted numerous times on these forums about my G550 and rust problems. One problem area in particular is the front windscreen. I've devised a system to help mitigate rust that involves using a large industrial dehumidifier, fans, and rubbing WD40 along the seals once a week.
I currently have two small oxidation bubbles on the windscreen. Even after a body shop takes them out, the problem of water being trapped behind the seals will persist. I'd like to remove the seals and apply LPS to the inside of the seals to help prevent future oxidation, then reapply the stripping. Is it difficult to remove and reapply the weatherstripping? Will the seal be the same once I reapply it or will it be less effective at keeping water out?
Thank you.
Old Jun 12, 2020 | 01:21 PM
Lawrence1's Avatar
2011 G55 + others
you can't remove the seal without removing the windshield. Not sure what LPS is but you'd want to apply it before reinstalling the windshield. This car does not have glued in glass like modern cars so those seals you see are actually channeled window gaskets that hold the glass. Older pick-up trucks had this type of glass in the rear of the cab. Those small bubbles, if they're on the metal windshield frame, you have rust. period. Small or large, the glass should be removed and that should be addressed ASAP. You will want to replace the windshield gasket and start fresh. I think lifting the gasket up after the car gets wet (i.e. parked or driven in the rain, washed, etc.) to let water drain probably help, but I live in CA, so no salt anywhere. It's an inherent design flaw with this car so not sure much more can be done.
Old Jun 12, 2020 | 03:00 PM
newyorktoLA's Avatar
2020 G63, 2021 E450 All-Terrain Wagon
What's also interesting is that on the new MY19+ models, while they removed the rubber channels on the windshield and rear door window, they added the rubber moldings to the driver/passenger doors around those windows. Not sure why they did that, but I don't think rust will form as the rubber seals are much tighter and very difficult to lift/manipulate compared to the thin and flexible rubber on the windshield of the older models.
