King steering shock
I called King about it pulling to one side now after i installed . They said i can buy $150 in tools to adjust. Ordered factory gonna sell useless king. Bryan from Gwagen parts e mailed me couple days later and said i can send back if i am not satisfied, thats great customer service
I called King about it pulling to one side now after i installed . They said i can buy $150 in tools to adjust. Ordered factory gonna sell useless kimg for 1/2 i paid on e bay. I hate aftermarket sometimes
I still have the King stabilizer, but I ended up buying a non-ATS Fox 2.0 stabilizer instead (https://jackwagonoverlanding.com/col...ing-stabilizer) because I haven't gotten any help figuring out how to make the King work properly (King and gwagenparts haven't been very helpful). The Fox stabilizer bolts directly on and is noticeably larger than the King.
FYI... the ATS version of the Fox 2.0 steering stabilizer does not work if you have a VTS differential cover on your front diff (https://www.g-wagenaccessories.com/p...n-and-sprinter). If you want the ATS version of the Fox, you need the OEM diff cover unless you want to grind away at the bracket that Eurowise created for the ATS version (https://shop.eurowise.com/product-p/w463fss.htm). I wanted to put both the ATS and non-ATS versions on, but I just had to return the ATS to Eurowise because of the VTS diff cover I have. If only Eurowise had disclosed that the ATS stabilizer only works with the OEM diff cover. It would've saved me the 15% restocking fee!
I recently upgraded the suspension on my 2005 G55 to G63 springs and Fox 2.0's from Eurowise. Shock kit worked fine overall but I've been getting a really bad flexing/wobbling at higher speeds over rough pavement (NJ/NYC roads are mostly terrible). I'm thinking it's my steering shock on its way out since I can feel the wobble being transmitted through the steering wheel, then into the chassis. I'm thinking of going with the Fox 2.0 non-ATS steering stabilizer to solve this issue, but wanted some input from others if they were feeling the same type of thing.
My reasoning is now with the softer suspension/shock setup, the road forces from bumps, cracks, joints, dips, etc are now easier to transmit to the steering, then to the chassis. With the OE G55 suspension, everything was so stiff that the steering was kept mostly in line since basically nothing was moving when you went over rough stuff.
what setting are you running on your FOX when not off roading? I have FOX 2.0 adjustable with Thor springs and had same issues at first. I run stiffest setting on all four corners and have replaced my steering dampener with factory bilsteins. I have about 3-4 inch lift, running 34’s Nitto Grapplers. It drives fine. Never flat and solid as factory setup but considering the changes, I wouldn’t expect that. It drive fine for everyday driver. Hope this helps. I
I've been playing with the shock settings over the past few weeks to find out what is the best setting for daily use. I'm currently settled on running the shocks full soft for the front and rear. I originally was at 2 clicks off soft in the front and 3 clicks off soft in the rear and the truck would shake violently and the steering wheel would be pulled with a good amount of force in random directions when driving over bad road surfaces. I have found that the stiffer the shock settings, the more violently the truck shakes when driving over rough roads.
Also, one thing to note, I have also found that the shaking is worse when first driving the truck (everything is "cold"). The steering shaking gets more mild after a few miles (I'm guessing as the fluid in the steering stabilizer heats up). This also points to the steering damper being the culprit.
