Wheel spacers
Old Dec 21, 2020 | 12:47 AM
z168's Avatar
3phase-4pole
Wheel spacers
Looking to install spacers on a 2015. Not looking for anything too aggressive just want to bridge the big gap between the tires and the flares.
Looking for suggestions on size. Is a squared approach better or staggering the spacers is preferred? Inputs appreciated
Old Dec 21, 2020 | 02:09 AM
rudys_500's Avatar
2002 G500 thulit red
did you use the search function yet?
you might check: "go big or go home"
Old Dec 21, 2020 | 02:40 AM
z168's Avatar
3phase-4pole
Thanks - found Limey Hooligan's post. 50mm might be a bit too much. Looks like 31mm is the consensus and avoid bottoming out the stock lugbolts
Old Dec 21, 2020 | 09:17 AM
streborx's Avatar
Top Answer: 1
G550
Don't go so wide that your tires spit road debris onto your car behind your fenders - the fender flares are there for more than just looks.
Old Dec 21, 2020 | 12:48 PM
Limey Hooligan's Avatar
2012 G550 - Capri Blue Metallic
Gee.... mud guards.
Old Dec 21, 2020 | 01:12 PM
z168's Avatar
3phase-4pole
Originally Posted by Limey Hooligan
Gee.... mud guards.
Haha right you are! I'm not quite there yet. Once I do the 31mm maybe after some time I may have the itch to go 50mm.
Meantime I'm still concerned about premature wear on the wheel bearings. Spacers on passenger cars are not a problem but bec of the heft of the G it can be.
Old Dec 21, 2020 | 06:02 PM
streborx's Avatar
Top Answer: 1
G550
Gee.... mud guards.
Can you recommend a source for rear guards that will fit a 2019?
