Nabzy - Please! More on 2003, options, etc!
I see from other posts (e.g. new E series) that you have some seriously good source for what's coming down the pike.
Do you have anything more on the 2003 - I see messages like "production starts July 1" and "mine is being delivered Aug 19th as a 2003" but of course, nothing official.
There are very few changes planned for the 2003 G-class and those have been posted here before. I also found the following link on another forum with more info:
http://forums.mbnz.org/forums/gclass...sp?messid=7467
Ask your dealer when they expect to start recieving 2003 ML or C-class models and they'll tell you mid August. The late November introduction of the 2002 G-class was because it was a new model, but the 2003 models will arrive at the same time as other MB 2003 models. In general, it takes about 6-8 weeks from production to delivery of the US version of the G-class (at least in California).
What's interesting is that the COMAND system in the 2003 G-class is still CD-ROM based, but it has an optional harmon kardon sound system. That is interesting because the COMAND system is manufactured by Blaupunkt/Bosch, but the second generation COMAND is supposed to be built by Becker/Harmon and based on a DVD-ROM according to:
http://mbspy.bacosys.be/comand.htm
2004 SL55, 2015 A250d, 2016 GLC250d
MB seem to have kept the option number (810) for the Harmon Kardon system the same as the one used for BOSE.
I imagine this is "confusing" their print department, and in fact it has the BOSE system.
The new DVD comand and HK system use the MOST bus for digital communication between all the bits. The old COMAND (etc) use D2B. So I doubt its possible to connect the HK system to a old COMAND system
Hi,
I will post an official comprehensive german dealer information for your information (from the great german site www.viermalvier.de)
It's completely in german, but for those of you who can read a little in this language, very useful information.
Perhaps, someone wants to translate it into english :-)
All those changes are valid with the production of cars from july,1st 2002. I don't know if all of the information ist valid for the american market!
Version G-Klasse Umfänge Aenderungsjahr 02
nachfolgend informieren wir Sie über die Umfänge des Änderungsjahres 02, die ab 01. Juli 2002 in die Produktion einfließen.
1. Umfänge Änderungsjahr 2002
Neue Serienausstattungen
Außenspiegel
Die völlig neu gestalteten Außenspiegel werden ab dem Änderungsjahr 02 mit integrierten Blinkleuchten und Vorfeldbeleuchtung geliefert. Während die seitlichen Blinkleuchten oberhalb der Zierleisten entfallen, bleiben die Ausstiegsleuchten in den Türen erhalten.
Beifahrerhaltegriff
Der Serienumfang des G 270 CDI und G 320 wird um den Beifahrerhaltegriff in Leder ergänzt.
Dachhimmel
Zur Erhöhung der Wertanmutung wird der Dachhimmel und die A-Säulenverkleidung bei der Ausführung mit langem Radstand neu gestaltet.
Handbremse
Die Aufwertung der Optik und Haptik wird durch die Ummantelung des Griffes der Handbremse mit Leder erreicht.
Multifunktionslenkrad
Das bisherige Multifunktionslenkrad wird ersetzt durch das neue W211-Multifunktionslenkrad. Die elektrische Lenkradverstellung befindet sich nun mehr an der Lenksäule.
Neue Sonderausstattungen
Cupholder vorne und hinten ( Code FG 2)
Der Lieferumfang der Cupholder umfaßt einen Cupholder vorne und zwei Cupholder im Fond. Der vordere abklappbare Cupholder mit Netz befindet sich rechts neben dem Wählhebel des
Automatikgetriebes an der Mittelkonsole. Die Cupholder im Fond sind hinter der Mittelkonsole auf der Batterieabdeckung positioniert. Sie sind mit zwei Zentrierspangen versehen, die für besseren Halt sorgen.
Gummimatten (Code V 46)
Auf vielfachen Kundenwunsch wird der Lieferumfang „Gummimatten“ geändert. Ab Änderungsjahr 02
sind die Gummimatten im Fahrgastraum für alle Fahrzeugtypen (auch G 400 CDI und G 500) verfügbar.
Die bisher mit diesem Code mitgelieferte Laderaummatte ist nicht mehr im Lieferumfang enthalten.
Diese kann ab diesem Zeitpunkt separat unter Code VL 4 dazu bestellt werden.
ISOFIX-Kindersitzbefestigung im Fond (Code SD 0)
Neu bei der G-Klasse ist nun auch die "ISOFIX"-Kindersitzbefestigung erhältlich. Mit deren Hilfe lassen sich zwei spezielle "ISOFIX"-Kindersitze einfach, schnell und sicher im Fond installieren.
Die Kindersitzbefestigungen stehen für den rechten und linken Sitz der Fondsitzbank zur Verfügung. Diese SA ist nur bei den Fahrzeugen mit langem Radstand bestellbar.
Lenkrad heizbar (Code VL 0)
Erstmals mit Änderungsjahr 02 wird ein heizbares Lenkrad angeboten. Die Sonderausstattung ist verfügbar für die Ausführung Lederlenkrad oder Holz-Leder-Lenkrad, wobei nur der Lederanteil beheizt wird. Die Bedienung der Heizung wird durch einen Hebel an der Lenksäule vorgenommen.
Kraftstoffilter mit Wasserabscheider (Code KL 5)
Insbesondere in den Ländern mit einem hohen Wasseranteil im Dieselkraftstoff ist der Kraftstofffilter mit Wasserabscheider von großer Bedeutung. Der für den G270 CDI und G400 CDI
lieferbare Kraftstofffilter scheidet mittels eines speziellen Filterpapiers das im Dieselkraftstoff enthaltene Wasser ab. Durch einen Wasserstandsensor wird über eine Kontrollleuchte, die anstelle des Ablagefaches vor dem Wählhebel des Automatikgetriebes installiert wird, angezeigt, daß der Behälter entleert werden muß. Der Behälter hat ein Fassungsvermögen von 250ml und wird unter dem Fahrzeug auf der Höhe des Verteilergetriebes fahrerseitig am Rahmen montiert. Um die Wasserabscheidung auch bei Temperaturen unter +10°C optimal funktionsfähig zu halten, wird der Kraftstoff mittels eines sich selbst steuernden Heizelementes vorgewärmt.
Soundsystem "harman/kardon" (Code E 66)
Das neue Soundsystem wurde speziell auf die G-Klasse abgestimmt und umfaßt 10 Lautsprecher. Der Verstärker hat eine Leistung von bis zu 8 x 40 W, 4 Hochton- und Tieftonausgänge und eine integrierte Frequenzweiche. Das Soundsystem „harman/kardon“ vermittelt somit ein perfektes
Klangerlebnis. Der Verstärker befindet sich unter dem Fahrersitz, der Subwoofer ist unter dem Fondsitz untergebracht. Diese SA ist nur bei den Fahrzeugen mit langem Radstand bestellbar.
Multikontursitz für den Beifahrer (Code SM 8)
In Ergänzung zum Fahrer-Multikontursitz, Code SM7, ist ab Oktober 2002 der Multikontursitz für den Beifahrer ebenfalls lieferbar.
Lackfächer
Die Lackfarbe Circongrün (6 257) wird zum 01. Juni 2002 durch Cubanitsilber-Metallic (9 723) ersetzt.
Der Standardlackfächer der G-Klasse setzt sich neu zusammen aus:
· dem Lackprogramm der neuen E-Klasse (ohne Sonderlackierungen)
· den designo-Lackierungen (siehe untenstehende Liste)
Farben auf Kundenwunsch/Produktionsauftrag
Farben von Drittherstellern außerhalb des Standardlackfächers sind auf Kundenwunsch gegen
Mehrpreis erhältlich. Folgende Prämissen müssen bei einer derartigen Bestellung erfüllt sein.
· Lack auf Wasserbasis
· Keine designo varicolor und chromaflair
Lacke
· Keine sonstigen Effekt- oder Speziallacke
2. Neuausrichtung des designo – Programmes
Ab 01. Juli 2002 umfasst das designo – Programm der G-Klasse die folgenden Farben.
Bitte beachten Sie, Basisausstattungsfarbe für die Innenausstattung ist schwarz.
2.1. designo Lackierungen
Das Angebot des designo Lackfächers besteht neu aus 7 Außenlackierungen:
Bezeichnung Code
designo brillantschwarz 0025
designo meerblau 0026
designo silber 0029
designo mokkaschwarz 0033
designo graphitgrün
designo mysticrot 0037
designo mysticblau 0032
2.2. designo Lederpolsterungen
Bei den designo Lederpolsterungen wurde eine Umstellung auf einfarbiges Leder vorgenommen. Ab 01.
Juli 2002 sind folgende 10 Lederpolsterungen einfarbig wählbar:
Bezeichnung Code
designo anthrazit ZH1
designo hellbraun ZH2
designo dunkelbraun ZK1
designo silber ZK2
designo mysticblau ZK3
designo mittelgrau ZK4
designo meerblau ZK5
designo sand ZK6
designo graphitgrün ZK7
designo mysticrot ZK8
Ab September 2002 zusätzlich
Bezeichnung Code
designo seide ZK9
Hierzu sind keine Preisänderungen vorgenommen worden.
2.3 designo Zierteile
Die Auswahl an Holzzierteilen sowie die Preisstellung bleibt unverändert.
3. Preisliste / MBKS
Alle Aenderungen sind per sofort im MBKS eingepflegt, fliessen aber erst bei der nächsten Neuauflage in die Preisliste ein. Bitte berücksichtigen Sie diesen Aspekt bei Verkaufsverhandlungen.
Außenspiegel
Beifahrerhaltegriff
Dachhimmel
Handbremse
Lackfächer
Lacke
Bezeichnung Code
designo silber 0029
designo graphitgrün
Bezeichnung Code
designo silber ZK2
designo sand ZK6
Bezeichnung Code
designo seide ZK9
It's not perfect, but I used the translation software on Google.
Change year 02 we inform you in the following version g-class of extent about the extent of the change yearly 02, which flows starting from 01 July 2002 into production. 1. Extent change year 2002 new standards outside mirror the completely again arranged outside mirrors are supplied starting from the change year 02 with integrated turn signals and apron lighting. While the lateral turn signals are void above the trim, the door lights in the doors remain. Front seat passenger hand grip the series extent of the G 270 CDI and G 320 is supplemented around the front seat passenger hand grip in leathers. Roof sky for the increase of the value seeming is arranged new the roof sky and the A-Saeulenverkleidung during the execution with long wheel base. Emergency brake the revaluation of the optics and Haptik is reached by the shroud of the grasp of the emergency brake with leather. Multi-function steering wheel the past multi-function steering wheel replaced by the new W211-Multifunktionslenkrad. The electrical steering wheel adjustment is now more at the steering column. New special equipments Cupholder in front and in the back (code fG 2) the scope of supply of the Cupholder covers a Cupholder in front and two Cupholder in the rear. The front hinged Cupholder with net is right beside the selector lever of the automatic transmission at the center console. The Cupholder in the rear is positioned behind the center console on the battery cover. They are provided with two centering clips, which provide for better stop. The scope of supply "rubber mats" is changed for rubber mats (code V 46) on multiples customer's request. Starting from change year 02 the rubber mats are available in the passenger compartment for all motor vehicle types (also G 400 CDI and G 500). The loading space mat provided so far with this code is not contained no more in the scope of supply. This can be ordered starting from this time separately under code VL 4 in addition. ISO fixed child seat attachment in the rear (code SD 0) new with the g-class is now also the "ISOFIX" Kindersitzbefestigung available. With their assistance two special "ISOFIX" child seats can be installed simply, fast and surely in the rear. The child seat attachments are to right and left seat of the rear seat for at the disposal. This SA is orderable only with the vehicles with long wheel base. For the first time steering wheel heatable (code VL 0) with change year 02 is offered a heatable steering wheel. The special equipment is available for the execution leather steering wheel or wood leather steering wheel, whereby only the leather portion is heated. The operation of the heating is made by a lever at the steering column. In particular fuel filter with water trap (code KL 5) in the countries with a high wasseranteil in the Diesel fuel is the fuel filter with water trap of great importance. For the G270 CDI and G400 CDI available fuel filters separates the water contained in the Diesel fuel by means of a special filter paper. Over a control light, which is installed in place of the shelf before the selector lever of the automatic transmission, it is indicated by a water level sensor that the container must be emptied. The container has a capacity of 250ml and under the vehicle on the height of the transfer case driver-laterally at the framework is installed. In order to keep the water separation optimally functional also at temperatures under +10°C, the fuel preheats itself by means of a steering heating element. Sound system "harman/kardon" (code E 66) the new sound system was co-ordinated particularly with the g-class and covers 10 loudspeakers. The amplifier has an achievement of up to 8 x 40 W, 4 high clay/tone and low clay/tone exits and an integrated frequency switch. The sound system "harman/kardon" obtain thus a perfect sound experience. The amplifier is under the driver's seat, the Subwoofer is accommodated under the fondsitz. This SA is orderable only with the vehicles with long wheel base. Multi-outline seat for the front seat passenger (code SM 8) in addition of the driver multi-outline seat, code SM7, is likewise available starting from October 2002 the multi-outline seat for the front seat passenger. Lacquer fan the enamel Circongruen (6,257) is replaced to 01 June 2002 by Cubanitsilber Metallic (9,723). The standard lacquer fan of the g-class exposes itself again together:·the lacquer program of the new e-class (without special lacquer finishes)·the designo lacquer finishes (see following list) colors on order for customer's request/production colors of third manufacturers outside of the standard lacquer fan are available on customer's request against additional price. The following premises must be fulfilled with a such order.·Lacquer on water basis·None designo varicolor and chromaflair lacquers·No other effect or special lacquers 2. Reorientation designo - covers program starting from 01 July 2002 designo - program of the g-class the following colors. Please consider you, basic equipment color for the interior equipment are black. 2.1. designo lacquer finishes the offer designo of the lacquer fan again consists of 7 external finish: Designation code designo brilliantly 0025 designo sea-blue 0026 designo silver 0029 designo mokkaschwarz 0033 designo graphite-green designo mysticrot 0037 designo mysticblau 0032 2.2. designo leather padding with designo the leather padding a conversion to in-colored leather was made. Starting from 01. July 2002 the following 10 leather padding are in-colored selectable: Designation code designo anthracite coal ZH1 designo light brown ZH2 designo dark-brown ZK1 designo silver ZK2 designo mysticblau ZK3 designo centralgrey ZK4 designo sea-blue ZK5 designo sand ZK6 designo graphite-green ZK7 designo does not mysticrot ZK8 starting from September 2002 additionally designation code designo silk ZK9 for this price adjustments was made. remains unchanged to 2.3 designo Zierteile the selection to Holzzierteilen as well as the quotation. 3. Price list/MBKS all changes is in-maintained by immediately in the MBKS, flows however only with the next new edition into the price list. Please you consider this aspect with sales negotiations.
amg, brown, change, covers, cupholder, designo, g55, light, ml63, mokkaschwarz, multikontursitz, multioutline, nderungsjahr, varicolor, year, zh2, zk6
