Phone Mount
personally it’s a nicer cleaner look, and I swapped the op of the mount to a MagSafe so that it not only mounted but charges at the same time
let me know your thoughts
Doesn’t obscure the factory buttons
Allows full travel of the passenger seats
the swan neck
and the magsafe mount
you WILL need to modify the swan neck! the BASE needs to be resized to fit inside the seat rail. if you have a dremmel you simply cut (see my crude diagram). i then touch up painted to black
you need a star torx socket to mount the bracket. (simply loosen the oem bolt and slide your swan neck mount into position and retighten!)
next you HAVE to modify the phone mount . this is a case of using the dremmel again to cut the TABS of the swan neck mount, and also removing the OEN mount off the magsafe holder. i then simply superglued the swan neck bracket to the back of the mage safe holder!
wiring - i simply ran the wire from the cup holder (using a 12 volt adapter to the USB).
hope that helps
