Can the brush guard be lowered without the wrench?
Thank you.
Here's a picture of the brackets on the truck with the brush guard lowered
The quick release bolt look like this:
You can stick anything in there that will fit in the space and allow you to turn. I made a 3D printed tool for this a while back but it doesn't stand up to much force, so I scrapped the project. I have since just replaced the quick release bolt with a correctly sized bolt and lock washer.
I have lowered the guard before but I cannot seem to find the tool for it anywhere. Quite frustrating.
And what do you mean by "recesses on opposite sides of the quick release bolt"
Thank you!
Get the two adjustable pins positioned in two of the slots in the quick release bolt, twist 90 degrees and the bull bar will be free to drop down from the bottom hinges.
Then all you have to do is slide to one side and it comes right off.
It seems as if the quick release bolt won't line up laterally with the cylinder mounted on the brush guard. I made sure the guard was aligned properly and it appears to be mounted properly on the horizontal pins located at the bottom of the front bumper:
Any advice?
Is your driver side quick release also the same amount offset? You may have to push the brush guard slightly toward the passenger side to get it to fit. Also make sure the brush guard is sitting completely flush against the flange on the lower pin. There should be little to no gap where the brush guard hinges downwards.
There is some adjustment in the brackets themselves if you want to try that. There are 2 nuts on the under side of the bumper that fix the bracket holding the quick release bolt to the bumper. The also have some play in them. To access them you have to remove the fog light. I would caution this as there is basically an infinite amount of adjustability in these brackets so you could be fiddling with it forever.
