Please Read. Emergency Situation - On Vacation Car Won't Start
BTW, what scanners do you own? I've been wanting to upgrade mine to one that's more MB intensive, and am looking for recommendations.
1- You can try to tip-tap around gently (prefuse module, SAM modules, Ignition Key module, driver footwell, passenger footwell...) while you have someone hold the ignition key in crank position - This might very well wake up a flaky relay and a bad ground screw with oxidized contacts... nothing to loose. I'd concentrate on what's switching heavy DC power
Sorry to hear such a diagnostic
. I am sure some people in the forum would love to do a post-mortem study on your FrontSAM because that is not a wear item, and understanding the failure modes of those modules will help other in preventative maintenance.These cars seem to have "water intrusion issues". Do you recall opening the front fuse/relay box under the hood recently? If the cover of the front SAM is not properly closed in place, and rainwater manages its way in, the car is bound for all kinds of electrical gremlins.
Pls keep us posted if that new SAM does not resolve all your glitches... high-tech is hardly ever simple.
I have a *good* handle on servicing my cars. But with old cars sometimes you just never know. Which is why - sadly for a car enthusiast - I always get a rental when I go on trips.
the Park brake isn't ABS operation or weather related - what I'm saying is as the ABS sensors "age" the first symptom is strange behaviour of the park brake (because part of the way they work relates to info from the ABS sensors) as the info they pass gets sketchy the park brake sometimes does odd stuff - your pre safe brake might do an extra bong as you drive off too
