G63 rear window washer line leaking
Subscribe
Nov 2, 2021 | 12:17 AM
I noticed that no fluid was coming out of the rear window spray. Wiper works fine. Pump works fine. I open the rear door and see fluid on the inside lining of the drivers side rear panel, where the 12V plug is. I figure the fluid line must be cracked and is leaking. Any word on how to fix this? Any help would be appreciated.
Reply 0
Nov 2, 2021 | 08:29 PM
Obviously you need to pry off the trim panel to expose what's going on behind. Usually not too difficult if you have the right tools. Maybe the hose abraded against a sharp metal edge. Spontaneous cracking would seem unusual unless the fluid froze.
Reply 0
Nov 3, 2021 | 03:27 PM
I figured this. Have you heard of this being a common issue? I've tried my best to find anything on this to no avail.
Reply 0
Subscribe
Currently Active Users (1)
