Tire suggestions
I'd like to go with either 275 70R18 or 285 70R18 (I'd like the 285's but I'm not sure if they will fit - I'm going to take it to my tire shop after I have the spring/wheel spacers installed). I ordered 40mm spring spacers and 30mm wheel spacers.
I do a decent amount of overland and winter driving but I also need something that is decent on-road as a majority of the miles driven will be on roads.
Toyo A/T III's have great reviews but I can't find them in 285 70R18. Any ideas on what I should be looking at? Does anyone have similar tires on their G? How do you like them?
your flares should deal well with at least a 305( they're 23MM narrower then a G63/55 each side) and with the spacers your scrub radius will be fine on the inside/ control arm/rear lower fender edge.
a 305/65/18 is roughly 33.6".... https://www.tirerack.com/tires/tires...CAT3&tab=Sizes
these are the 325's - with rim at about same offfset at you'll be at with the wheel spacers.... hopefully someone with a 500/550 can weight in....
Mileage.... ugh - don't even bother to calculate it..... I know on my G63 it was about 1 mpg less with the larger OD setup, but even at 34" the overall weight was less then the stock setup with spacers due to the forged rims...
E
