2002 G500 Transfer Case Shift Problems
Just for fun I swapped the original sift motor back in and same error when re-learning and fault codes.
So seems like it is the TC control module at this point unless there is a wiring issue I'm not seeing? Is it common for the module to fail with the codes I'm getting? I'm new to Mercedes programming, is there any way to update the firmware on the module to maybe resolve this? Probably not a good idea to buy a used TC module off ebay since these fail often so my only option is the MB dealer?
Start the truck, put it in Neutral. Hold down the “low” button for 10 secs, then hold the “high” button for 5-10 seconds. You should see the little box to the right of your D indicator turn to H.
I'll probably buy a new module from Mercedes. Looks like the new part number is 463-901-07-00 which replaces 463-545-08-32, 463-545-21-32, 463-545-25-32, 463-545-27-32, 463-901-07-00-64. Cheapest price I can find online is $384 + $5 shipping.
Some other thoughts on this I checked in Vediamo(Mercedes factory coding tool) to see if the max shift distance could be programmed but couldn't see anywhere.
I thought I had figured out my TC issues after replacing the TC motor and relearning using STAR/Xentry. It has been working well after replacing my TC Motor and relearning with STAR/Xentry for the past 2.5 months.
I was digging around in STAR/Xentry the other day (nothing related to the TC) and this error just popped up. H/L indicator in the cluster disappeared and started getting the "TC in Neutral" again. Car drives like normal but it won't switch into Low, it just goes into Neutral. If I shut the G off, it will reengage High and drive like normal. I've tried the reset procedure and this doesn't do anything either. (Hold Low for 20 sec, then hold High for 20 sec)
I've tried the TC relearning procedure and get the P2213 error - nothing I do seems to fix it.
I have tried swapping in a NEW TC motor (from FCPEuro), thinking something went wrong with the sensor circuit inside the motor, but this is not the case. So I'm out of ideas.
If anyone has a STAR/Xentry setup, can you read the "Alle Werte", "Position Data of Sensors", and "Shift Motor" Information menus and post them up?
Any help would be appreciated!
I THINK I may have figured out the issue. Not solved yet, but actively working on a possible solution.
My battery was last replaced in 2017 by a previous owner and I noticed it was struggling sometimes. It made sense to just replace it, so I dropped in an Odyssey Group 49 AGM and was keeping any eye on system voltage through the Xentry system as I did notice in the past the voltage dipping below 11.6V and a red circle being displayed next to the value, where normally it would be green (I'm guessing for 'good voltage').
This is a screenshot of my Transfer Case Alle Werte (All Values)
The Transfer Case Motor Voltage +/- is out of the specified range, 6.6V vs the expected 7.5V-8V. With the G motor running (alternator running), the Battery Voltage is in the 13V range and the TC motor voltage is correct being 7.8V.
I left the G on a battery tender for about 30 min and was able to get the TC motor voltage up to 7.3V, so this may just be a waiting game for the voltage to be in the right range to be able to correctly run the learning procedure.
Anyone have any idea why this Voltage value would be low with the ignition on and motor off? I would expect this range to be a lot higher, or the voltage regulation to be more accurate, unless there is some other parasitic draw on the system somewhere else.
Crossing my figures that this is it.
Shifts into H/L fine, sometimes misses Low and grinds when put in gear. I replaced the TC motor and could not run the learn procedure, same error codes.
What's interesting is the "distance learned" of 31.875mm is exactly the same on mine.
Bad TCCM or dead battery??
Mine does not shift into L. If it ever does go into N, it does grind when trying to put it into H, but never goes. The only way I can get mine back into H is to shut the G down, and start it up again. The default mode is to force the TC into H, which mine will do after a few starts.
The "distance learned" of 31.875mm, I believe, is the maximum distance before the process times out, which would make sense why you are seeing this also.
My battery is new, so not an issue. I also have tried running a tender on the battery during calibration, as well as jumper cables from a running car to boost up the internal voltages. Did not work.
My TC computer could be on the fritz - I need to remove the center console to see if there is any water damage or any signs of issues. I also need to check the continuity of the wiring harness. Another member on the ClubG forum also pointed me in the direction of looking at other systems with with STAR/Xentry, so I plan to work through that this weekend.
In a last-ditch effort, I also picked up a used known good transfer case that I can swap in if everything else fails to solve this issue.
There are a lot more updates on the ClubG thread so take a look over there also.
https://clubgwagen.com/forum/viewtopic.php?f=18&t=14082
