2011 G55 Code P0442
Old Feb 5, 2023 | 07:55 PM
selenite_C63s's Avatar
2017 C63s AMG, 2020C300, 2011 G55 AMG
2011 G55 Code P0442
I have been battling with the P0442 code for a few weeks now.
Had local indy shop go over everything and perform a pressure test on my fuel system. Results indicated all pressure, etc was good.
A few weeks later I had the same code, back to shop, replaced the gas cap. A few more weeks of no code.
Code is back now - anyone have this issue or any tips on putting this to bed?
Thanks in advance!
Old Feb 5, 2023 | 08:14 PM
Texas E63's Avatar
Built 2008 G55 & one big 80 Series LandCruiser !
where are you located ? the collective intel might have a local Indy to share based on that.....
E
Old Feb 5, 2023 | 08:48 PM
I’m located in New Orleans, La!
Old Feb 6, 2023 | 06:41 AM
Texas E63's Avatar
Cool- I live in Houston, but am in VA 3 weeks a month these days for work.
Adam/Dave over at Eurocharged in Austin would be my go to for something like this.... they'd did the tuning and mods on my C63 and E63 but also di the full baseline and tranny rebuild when needed on our new G55 project. They know the 55's inside and out....
Did you keep the C when you moved into the G ? Plans for the G ?
Erich
Old Feb 6, 2023 | 04:26 PM
croat's Avatar
02 ML320
EVAP systems need to be properly diagnosed. Every car has different procedure based on the code set. In this case, if you want to throw more parts at it, I'd replace Purge Valve
